586,094 active members*
4,177 visitors online*
Results 1 to 8 of 8
    Feb 2021
    Cleaning Tormach drill chucks
    Just got some new tooling from Tormach. The drill chucks have a bunch of dried cosmoline (or whatever they use) stuck behind the teeth and on internal parts of the jaw.
    I’m debating whether these are high enough quality to take apart or if I should just leave it. It probably doesn’t affect function, albeit it’s hard not to visually notice.
    What do your all do?
    Nov 2007
    2151
    Re: Cleaning Tormach drill chucks
    Quote Originally Posted by jpalley View Post
    I spray new tools or tooling with wd40 then tooth brush, wipe down and set it tray to dry. Repeat if its still sticky. I have used other cleaners in the past but tend to do this because its always on the shelf handy. tts or bt taper shafts I clean with rubbing alcohol every 4-6 months.
    Apr 2013
    1788
    Rather than WD40 I use carburetor cleaner (Gunk or a cheaper substitute from my local discount auto parts store). Vigorous wiping with a rag saturated with cleaner helps to remove the sticky stuff. For moving parts like a drill chuck I then apply a few drops of air tool oil.
    I like WD40 too. Brake clean or rubbing alcohol for TTS shafts works fine.
    Nov 2012
    591
    I use paint thinner in a steel tray. Then just wipe off with a cotton cloth. Works a treat!
    (And if there's really bad stuff, it comes off with acetone.)
    I just get a tin jug of each and keep in the garage, pouring out only what I need. I'm sure I temporarily go above the California VOC limits when I use it, but on average I'm still way under :-D
    Nov 2013
    402
    A 50-50 mix of Acetone and Transmission Fluid works great..
    Jun 2014
    1780
    I have always used fuel oil or kerosene to remove cosmoline or whatever its called.
    - - - Updated - - -
    mike sr
    Nov 2007
    2151
    I will mention here just because this bites me now and then.
    Use never seize on all threaded insert screws. Dont skip this even one time when changing inserts.
  1. Tool Tables and Drill Chucks
    By Mooser in forum Mastercam
    Last Post: 02-18-2017, 02:29 AM
  2. Drill chucks
    By skubajon in forum DIY CNC Router Table Machines
    Last Post: 09-26-2016, 11:11 AM
  3. Taking the chucks off your rotary tables periodically and deep cleaning.
    By pickled in forum Tormach Personal CNC Mill
    Last Post: 06-05-2015, 04:13 AM
  4. TTS drill chucks up for grabs - SOLD!
    By yantra3d in forum Benchtop Machines
    Last Post: 01-15-2010, 10:22 PM
  5. Looking for NMTB 40 integral drill chucks
    By petriej in forum Uncategorised MetalWorking Machines
    Last Post: 12-13-2007, 06:21 PM
