586,080 active members*
3,706 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Measuring Turning Tools Daewoo PUMA 6S
    Jul 2007
    42
    Hi Guys,
    We have just installed a PUMA 6S lathe and having a few issues with manual measurement of tools, it has no tool eye unfortunately.
    Normally on this kind of machine I would set use a measured tool and set Z by MZ0.0 in the workshift page, then every other tool can be touched off in Z and MZ0.0 in the tool geometry page.
    X is similar on our other machines, just cut a diameter and MX (whatever the diameter) in the tool geometry page.
    Not so on this Daewoo, I'm not quite sure if it is a parameter or two that is wrong.
    There is a Tool Measure button on the controller, but haven't had any luck with that either, there is no instructions in the manual for it.
    Any ideas?
    Cheers - J
    Jan 2010
    56
    Re: Measuring Turning Tools Daewoo PUMA 6S
    I'm having the same issue, were you able to solve this problem? Thanks in advance!
    Sep 2005
    274
    It's been a while since I ran one of these, I think you use Tool Measure button on the controller instead of the "M" X "M" Z , Try Typing X 1.5 or whatever, press Tool Measure button on the controller, then Input. No "M"
  1. Replies: 13
    Last Post: 08-01-2018, 06:10 PM
  2. Daewoo Puma 10 is off
    By AirChunk in forum Daewoo/Doosan
    Last Post: 05-15-2016, 01:15 AM
  3. Daewoo Puma 10
    Last Post: 05-02-2016, 03:18 PM
  4. daewoo puma 8
    By skippyfix in forum Daewoo/Doosan
    Last Post: 03-29-2014, 12:44 AM
  5. Daewoo Puma 10
    By Danny in forum Daewoo/Doosan
    Last Post: 02-04-2011, 11:08 PM
