586,119 active members*
3,490 visitors online*
    May 2020
    15
    Safety enclosure & Emergency Stop
    Hello,
    I am currently designing a safety enclosure for a small CNC machine that needs to have one main feature: if the doors are open, the user shouldn't be able to start a G-code or turn on the spindle. The machine should also go into E-stop mode if the door is opened during a job. I would like nonetheless the machine to be able to perform certain actions when the doors are open for ergonomic reasons, i.e. manual jog allowed, or using a tool measure length probe.
    I have two ideas in mind, both with advantages and drawbacks:
    1. Place a switch on the door frame, wired in series with the main e-stop switch. The advantage is that it will be reliable and work for the scenarios mentioned above, except that I won't be able to control the machine manually with an open door.
    2. Place a reed switch or a sensor on the door frame, wired to an input of the Mk3/4 controller. I modified the OnStart and M3 scripts to check the state of that pin before starting a job or turning on the spindle and it works well, but the issue here is: how to stop the program while it's running if the door is suddenly opened?
    Lastly, am I missing another possibility to achieve this?
    If someone already tried something similar or has ideas to give me, I'd greatly appreciate it!
    Mar 2017
    1312
    Re: Safety enclosure & Emergency Stop
    Use "Expr.txt" to monitor input pin.
    Then in global loop trigger e-stop is machine is running and input is triggered and in #OnStart event return NAN to abort,
    May 2020
    15
    Nice, thanks a lot for the fast and helpful reply!
    Another question though: how can I force the e-stop when the input changes? I mean with which syntax? I saw the variable _hw_estop in the documentation but it's read-only.
    May 2020
    15
    Ok so I solved it by using: exec(cmd('Machine.Emergency_Stop'))
    One last thing, could you show me what is the syntax to return a Nan value from the script? I couldn't find it in the documentation.
    Mar 2017
    1312
    Here is one solution using Expr.txt:
    Code:
    if(_hw_stop==0 && and(_hw_input,64), exec(print('Alarm!!!'), cmd('Machine.Emergency_Stop')));
    #OnStart
    if(and(_hw_input,64), exec(print('Alarm!!!'), nan()));
    In main loop, if machine is moving (_hw_stop==0) and inpit 7 is triggered and(_hw_input,64) we execute two things - print alarm and cmd for estop
    On on start event we check if input 7 is triggered. We also print alarm but we return nan and start is aborted if it is.
  1. Emergency Stop.
    By MrEmo in forum PlanetCNC
    Last Post: 10-20-2021, 05:26 AM
  2. Problems with Emergency Stop/Stop function.
    Last Post: 10-19-2021, 10:47 AM
  3. emergency stop condition after E stop
    By Cosmin90 in forum Fadal
    Last Post: 01-14-2020, 01:30 AM
  4. Making a safety enclosure - ideas for door mechanism?
    By Transition in forum Linear and Rotary Motion
    Last Post: 05-14-2012, 02:52 PM
  5. Generic Emergency Stop (E-Stop) Design Concepts?
    By zipzit in forum CNC Machine Related Electronics
    Last Post: 06-09-2011, 12:14 PM
