586,032 active members*
2,891 visitors online*
Results 1 to 1 of 1
    Oct 2021
    Lightbulb 6 Types of CNC Machines
    Computer numerical control (CNC) machines play an important role in the manufacturing industry. These complex machines are controlled by a computer and provide a level of efficiency, accuracy, and consistency that would be impossible to achieve through a manual process. The advanced machinery makes the world easier
    The Different Types of CNC Machines :
    1. CNC Milling Machine:-
    One of the most common types of CNC machines, a CNC mill utilizes computer controls to cut various materials. Mills can translate specific programs of numbers and letters in order to move the spindle in various ways.
    2. CNC Lathe:-
    A lathe is a CNC machine that functions to cut workpieces as they are rotated. CNC lathes can make precise cuts quickly by using various tools.
    3. What is a CNC Router?
    A CNC router is a machine that is very similar to the commonly used handheld router utilized for cutting various materials. This type of CNC machine can aid in the cutting of steel, wood, aluminum, composites, plastic, and foam.
    4. What is a CNC Plasma Cutter?
    The process of plasma cutting involves the cutting of a material using a plasma torch. This method is most commonly used to cut heavy materials, such as steel and other forms of metal.
    5. CNC Electric Discharge Machine
    Electric discharge machining, or EDM for short, involves creating a specific shape within a certain material by using electrical discharges, or sparks.
    6. What is a CNC Laser Cutter?
    Last but certainly not least, there are CNC laser cutters.
    These types of machines are similar to CNC plasma machines—the only difference is that lasers are mostly used for cutting and are great when it comes to cutting metals, plastic, or hardwood. Depending on the density and strength of the material, the intensity of the laser can be adjusted.
