586,268 active members*
3,529 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Daewoo Puma 230M - X axis overload
    Oct 2021
    Hello!
    We moved our Daewoo Puma into new place. Now when we start it up, the Alarm shows 409 - x axis overload.
    Overload is like 180% , but we dont know why. Machine didnt fall or anything when we move it.
    What can cause that problem? We checked spindle on X axis and it's ok.
    Best regards,
    Sribar
    Jul 2007
    42
    Re: Daewoo Puma 230M - X axis overload
    Check the terminals on the motor and make sure it hasn't come loose. I had the same issue and was told it was a faulty drive. Turns out the terminals were loose. Saved 7K on a new board.
    Oct 2021
    Thank you for answer. Can you tell me where is that terminal on the motor?
    Sribar
  1. Daewoo PUMA 230 MS w/Fanuc 18iT C-axis programming format
    By emexcee380 in forum Daewoo/Doosan
    Last Post: 03-23-2016, 10:24 PM
  2. Replies: 0
    Last Post: 04-17-2013, 06:26 PM
  3. Puma 230M left hand tapping
    By eric.lefavour in forum Daewoo/Doosan
    Last Post: 02-20-2010, 03:20 PM
  4. DAEWOO PUMA 10 Z AXIS PROB
    By harleydog in forum Daewoo/Doosan
    Last Post: 11-30-2008, 09:31 AM
  5. can the tailstock be programmed on Daewoo puma 230m
    By Bigbill in forum Daewoo/Doosan
    Last Post: 05-25-2007, 01:38 PM
