586,051 active members*
3,799 visitors online*
    Mar 2016
    8
    Mazak VCN-510 Matrix Control NO READY
    Hello
    Machine was off for a while. After swithed on "no alarms" but it didn't pull READY status. On servo amps. sais like "b1" "b2" "b4".
    External contactor is OFF state. So charge LED is off, if manually push contactor charge lamp is on state and power supplied to servo amp, but nothing happen still NO READY.
    How I understand driver not receiving ready on signal from NC. But what should avoid that signal?
    Mar 2016
    8
    Re: Mazak VCN-510 Matrix Control NO READY
    And found little "o" symbol on power source module. Some how there no error like that in datasheet about that.
    Mar 2016
    8
    We fix it, issue was brain board in power supply unit. it has some internal soft problem.
  1. MAZAK MATRIX CONTROL
    By darrelt in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-19-2018, 07:33 PM
  2. Mazak VCN 510-C motor encoder question
    By ghandee in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-08-2014, 09:33 AM
  3. Post for Mazak 510-C Nexus Matrix control
    By stinkfist in forum Post Processors for MC
    Last Post: 07-26-2011, 04:20 PM
  4. Absolute position data lost ATC Matrix VCN 510C
    By nexuss in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-19-2010, 05:37 PM
  5. VCN Matrix
    By operations1 in forum Want To Buy...Need help!
    Last Post: 10-02-2008, 11:51 AM
