586,036 active members*
3,446 visitors online*
    Laguna laser cuts are off
    Hi, I just signed up because Laguna wasn't able to help me solve this issue. We have a custom Laguna Tools 150w Co2 laser. 4ftx6ft. It was a floor model. We are in PA so it's too far for a Laguna tech to come to us unless we pay their way.
    So I have a few problems. One profound problem is that any curved shape, like a circle, tends to cut with a jagged line. It's not on all circles though. I will try to include a picture. I have dialed in the stepper motors so that my squares are 100mm x 100mm. I've also used several files versions and created circles in Ai, Inkscape, and RD works directly. I am using RD works to control the laser.
    Any ideas on what this could be?
    Attached Thumbnails Attached Thumbnails 20211026_121118[1].jpg   20211026_121110[1].jpg
    Apr 2004
    475
    Re: Laguna laser cuts are off
    Backlash
    The good circle is probably good because of the direction (of Y) the laser was moving to get to the start point.... probably the opposite of the bad circle.
    Tighten your belts and makes sure nothing else is loose. You can adjust in software but that's usually for smaller amounts or stuff you just can get rid of by tightening.
    The machine could be missing steps too, but backlash is more likely.
    Sent from my Nokia 3.4 using Tapatalk
  1. Misrepresented Laguna Smartshop Laser (MX, EX,...)
    By HoS2020 in forum Laser Hardware
    Last Post: 08-21-2021, 07:59 AM
  2. Laguna Tools Laser Cutter
    By Michaelmsg in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-09-2018, 01:38 AM
  3. Any Laguna Smartshop Laser users out there?
    By Willywonka321 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-11-2017, 08:40 PM
  4. colouring laser-cuts
    By maracv in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-13-2017, 09:08 AM
  5. New Tube but only cuts for 30second then laser cuts out
    By JBxrayman in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-11-2016, 05:57 PM
