586,106 active members*
3,009 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > How can I connect er11 collect to a spindle that support er20 collect
Results 1 to 8 of 8
    Sep 2016
    353
    I wish to mill a PCB using a high precision er11 collect but my CNC has a 2.2Kw spindle which only accept er20 collects. I tried to find an adaptor for this but could not find any. Any suggestions?
    Jun 2015
    4154
    Re: How can I connect er11 collect to a spindle that support er20 collect
    hy suspension, craft another shaft, with an er 11 chuck, then replace it using an adaptor will lead to more tir & overhang
    if you wish, i can help you with specific details / kindly
    Apr 2004
    5737
    The added precision gained by using a better collet will be lost by using an adapter, as deadlykitten is telling you above. Just find the right-sized ER20 collet for your PCB tool and use that.
    Andrew Werby
    Website
    15362
    Quote Originally Posted by suspension View Post
    There is no such adaptors, that I have ever seen, apart from a straight shank ER Collet holder, which you would not want to use in the ER20 Spindle, there would be no need for one. what ever size you want you can get it in the ER20 Size collet, with just the same precision, as the ER11.
    Mactec54
    Jun 2015
    4154
    is there interference with the er20nut, while 11 may make it ? instead of other size, maybe is enough to use a smaller nut
    15362
    Quote Originally Posted by deadlykitten View Post
    When this happens you can just machine up a solid tool holder to fit what ever ER holder you have, to give the amount of clearance you need, I Loctite the cutter into the holder, you can buy these also, they are easy to make yourself though.
    Mactec54
    Mar 2017
    926
    They make screw-on adapters to go bigger and smaller e.g.
    https://www.ebay.com/itm/15422087603....c101113.m2108
    And
    https://www.ebay.com/itm/35371366647...cAAOSwpOthYEMX
    I don't know how small the end mill is but can't you just use a stepped end mill with a larger shank like this:
    https://www.ebay.com/itm/33417734199...3ABFBMlKGbnZxf
    Or V shape bits with a 1/8" shank and a 0.1mm tip:
    https://www.ebay.com/itm/18510926519...UAAOSwzNRhal0N
    I can't imagine any sort of adapter adding precision....
    Sep 2011
    261
    Your best bet is to get an ER-20 Ultra Precision collet if you have a tool with at least a 2mm shank (the smallest ER20 goes I think?). A reducer doesnt provide any real benefit I can see here.
    https://us.rego-fix.com/en/products/...ions?system=ER
    But if you need more length for some reason, the regofix reducers linked above will take you down 1 size. I thought they went down more sizes than that, but dont see them in their current product list.
  1. Collect geometry problem
    By sino83 in forum PowerMILL
    Last Post: 04-11-2016, 06:59 PM
  2. Mounting 5c Collect Chuck - Help!
    By Ziuck in forum Mini Lathe
    Last Post: 05-31-2014, 04:24 AM
  3. Bosch router collect
    By Jur1 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2011, 07:13 AM
  4. Haas Machine Data Collect
    By wmpy in forum Haas Lathes
    Last Post: 10-29-2010, 12:25 AM
