586,076 active members*
3,912 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Milltronics ML-15 Spindle Encoder
    Mar 2005
    271
    I need to replace the spindle encoder on my Milltronics ML-15 cnc lathe.
    Milltronics quoted me $950 this is my garage lathe and don't want to spend that much, can anyone help me out with a replacement.
    This is the information on the encoder.
    Dynamics Research Corp.
    152-121-1000-18WAS
    SERIAL NO. 5692443
    Channel A+
    Channel A-
    Channel B+
    Channel B-
    ZR+
    ZR-
    Ground
    +5VDC
    Any help would be greatly appreciated.
    Thanks Mike
    Sep 2010
    529
    Re: Milltronics ML-15 Spindle Encoder
    I had checked for replacements on my mill back in 2013, below is the info I got from MicroE Systems. My parts number was different, so you probably need a slightly different model, but this should give you somewhere to look.
    Hello Brian,
    Thank you for your inquiry. The "direct" replacement for your old 152 encoder is the S154 - 4E18 - 47500.
    The only difference between it and your encoder is that it will have an 18" shielded cable rather than loose wires.
    This encoder lists for $310 each for quantity 1-9 pieces and carries an 8-12 week lead time.
    To place an order, please contact Lisa Braga in customer service at [email protected] or 781-266-5644.
    Regards,
    Dave Smith
    Sr. Applications Engineer
    MicroE Systems
    A: 125 Middlesex Turnpike
    Bedford, MA 01730 USA
    T: 781-266-5894
    F: 781-266-5112
    E: [email protected]
    W: Please Wait... | Cloudflare
    Jul 2010
    548
    Hi Catch22, I have replacement encoders for thee Milltronics. $285.00
    give me a call
    Sportybob
    952-288-6340
  1. Milltronics RW15D Spindle Orientation Parameter?
    By jsmith215191 in forum Milltronics
    Last Post: 05-13-2021, 06:45 PM
  2. Milltronics Centurion 1 spindle not turning.
    By Samandkimberly in forum Milltronics
    Last Post: 12-12-2017, 03:14 AM
  3. Milltronics VM-17 vfd spindle enable, spindle test.
    By plane captain in forum Milltronics
    Last Post: 02-10-2016, 04:36 PM
  4. Milltronics Spindle not working
    By cic108 in forum Milltronics
    Last Post: 08-15-2015, 08:59 AM
  5. New Spindle Encoder Twice the Resolution of Old Encoder - What to do?
    By ecnels in forum Vertical Mill, Lathe Project Log
    Last Post: 10-12-2013, 11:39 PM
