586,119 active members*
3,570 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > HiCell CA40II - tool registration by program
    Dec 2013
    29
    HiCell CA40II with an 8-position turret and 24-tool carousel in the back. Typically if we load a tool into the turret manually (because it is too big for the ATC), we dedicate that turret position to that tool. But if I have a program with a lot of tools, I need to reuse that turret position for another tool. This requires the tools to physically be swapped; and in that scenario, you also have to register the new tool in the control. However, I cannot find a way using a G-code, M-code, or T-code to change registered tools (it would have to be entered manually in the tool list screen). For example, on our vertical mill with Fanuc control, we can use M13Txx to change the registered tool in the spindle without actually initiating a tool change. Does anyone know if this is possible on the HiCell? And, if so, what's the code?
    May 2017
    11
    Re: HiCell CA40II - tool registration by program
    old post, but I use G10 P01 C3 R0.8 H3.0, etc. P01 is tool number, C3 is orient position, R is radius, H is tool width - grooving. Same applies to live tools
    Dec 2013
    29
    Hey Nifty, I don't recall ever seeing your response before now. But it appears you're correct. According to my programming manual, it would be G10 L20 P0300 Q0500 for tool #3 in turret position #5.
  1. program of tab program in mori sv 400 and program tool chance
    By hmtam1311 in forum Mori Seiki Mills
    Last Post: 12-10-2017, 02:54 PM
  2. Automatic tool changer program for a 8 tool turret Diy lathe cnc
    By tessen in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-04-2014, 05:05 AM
  3. program to park tool at the program end
    By Graven Hawk in forum HEIDENHAIN -> TNC
    Last Post: 02-23-2012, 05:43 PM
  4. Mits M-v5cn,meldas 600 control,duplicate tool registration error or out of sequence
    By davissammy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-04-2008, 04:39 PM
  5. 6MB Tool # registration program
    By steedspeed in forum CNC Machining Centers
    Last Post: 12-24-2006, 07:20 PM
