586,072 active members*
4,559 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Which bearings are best for a Taig spindle?
Results 1 to 2 of 2
    May 2006
    309
    I need to change the bearings in order to get less heat when engraving at higher speed and need to know if I can use the 6203/C3 option that will give an extra play when it gets hot. Anybody here withe experiences? Wil that extra play result in wider cuts with tiny engraving bits?
    Jun 2011
    68
    Re: Which bearings are best for a Taig spindle?
    Without active cooling in the Taig headstock... at High Speed....
    Hybrid Ceramic Bearing is the Only way to go.....
    Less thermal transfer, and expansion
    But Good hybrid bearing are expensive!!
  1. Replies: 0
    Last Post: 03-01-2021, 04:17 AM
  2. Spindle Motor for Taig ER16 Spindle
    By jupdyke in forum Taig Mills / Lathes
    Last Post: 04-15-2011, 05:33 PM
  3. Taig mill/lathe spindle bearings
    By japroach in forum Taig Mills / Lathes
    Last Post: 09-08-2010, 02:14 PM
  4. Lathe spindle bearings and spindle material
    By mackeym in forum Uncategorised MetalWorking Machines
    Last Post: 08-21-2007, 08:49 PM
  5. Lathe spindle bearings and spindle material
    By mackeym in forum Linear and Rotary Motion
    Last Post: 08-11-2007, 04:53 PM
