586,067 active members*
5,159 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > approach to corners 45 deg to grain direction
    Mar 2020
    20
    I have parts to cut out (I made a quick diagram attached) and I'm not sure how to approach the corner sticking out at a diagonal to the wood grain direction. I'm cutting in oak right now which is maybe the worst in terms of grain splitting but I also get the problem in walnut.
    It breaks a triangle off the end about 25% of the time.
    I'm climbing milling and slowing down from 140ipm to 35ipm around the corner with an 1/8th inch depth of cut, honestly I'm not sure what else I could try.
    Wondering if anyone has experience with this type of shape.
    Thanks!
    Mar 2020
    20
    Re: approach to corners 45 deg to grain direction
    So two years later and still having this issue! wondering if anyone might have some thoughts on the matter.
  1. Replies: 4
    Last Post: 05-18-2018, 07:39 PM
  2. Sanding Aluminum - with the grain?
    By tikka308 in forum Material Machining Solutions
    Last Post: 12-20-2017, 05:42 AM
  3. need to change direction of wood grain? Please help.
    By shutterguy in forum Solidworks
    Last Post: 09-25-2014, 05:09 AM
  4. Bowing of parts in relation to grain direction
    By penjas14 in forum Material Machining Solutions
    Last Post: 10-22-2013, 05:42 PM
  5. How to change direction of wood grain
    By foxsquirrel in forum Solidworks
    Last Post: 07-12-2010, 04:58 PM
