Hi all,
I'm looking at this router company on eBay and contacted them about the tables. They said that the company used to be Vortech Routers and one of the owner of the marketing company that is advertising for them, purchased the router company and is now building and selling them.
The prices are amazing for what you get. I got a price on the 4x4 table delivered from the east coast of the USA to Flagstaff Arizona. Here's a little about the table.
2007 4' X 4' Integrated Router System
Active Transit /Cutting speeds 900/700 IPM.
Mechanical home switches
Rack & Pinion on X and Y Drives, Ball Screw on z axis
Power 220V
Easy to use G-code controller
64 MB part program storage
Anti Backlash
Plug and play
Item Specification
Table Size 56" x 54"
X,Y,Z working area 49" x 49" x 6"
X,Y,Z Traveling Positioning Accuracy .0001"
X,Y,Z Repositioning Accuracy .002"
Frame Structure Steel
X.Y Structure Anti backlash Rack and Pinion
Z Structure Orbital Ball Screw
Max Speed 0-900 IPM
Max Working Speed 0-700 IPM
Spindle Power Motor High Frequency Conversion Water Cooled Motor
Working Mode 24000r/min
Working Voltage AC220V
Command G Code, hpgl, plt
Interface PC
Flash Memory 64MB
XY Working Tolerance < 0.02mm
Software Mach3, Type3 full function 3d
Packing Size 72" x 76" x 44"
Net Weight 720 lbs
The 4x4 System including Software, High Frequency Spindle and Inverter, T-Slotted Hold Down, Dust Collector Attachment and Bit Set is currently available for only $7,500. The regular retail price is $12k. Easy Financing is available for only $160 per month.
Available accesories: Spindle upgrade to 6HP $800, Table Vac Hold Down System with 10 HP Pump is $1700.
The routers carry a one year warranty with an extended warranty available. Most parts if ever needed can be sent next day. Free Lifetime Technical Support is available and onsite installation and training is available though the router arrives assembled and plug and play ready.
What do you guys think? That's a crazy good price for this right?
Here's the link to the 4x8 table, same specs for $9,995.00
http://cgi.ebay.com/ws/eBayISAPI.dll...m=130145937825
The shipping for the 750lb 4x4 table to Arizona was $388.00 total.
The 4x4 table is exactly the same constuction, just a shorter table.
Let me know, Thanks
Pete
