586,103 active members*
3,501 visitors online*
Results 1 to 13 of 13
    Mar 2020
    Macro programming help
    Hi. We have a bunch of Doosan puma lathes with fanuc control. Im a fairly experienced cnc programmer. But macros are very unknown for me. I want an easier way for operators to adjust programs. Im looking to make a simple macro program where u can edit x and z offset. We have alot of similar products with different lenght and dimension. I want to have the option to write in the lenght and diameter at the start of the program. But i have no clue how to do this. So i wonder if anyone could give me an example on how to do this?
    Re: Macro programming help
    Look up PROGRAMMABLE PARAMETER ENTRY (G10) in the programming manual for controller that is on your machine.
    Feb 2011
    353
    A couple of books that could help are
    fanuc custom macro b by Sihna
    fanuc cnc custom macro's by Peter Smid
    to have the program make changes to the machining of the part by having the operators change a macro variable
    #1-#33 ARE LOCAL
    #100-#199 ARE COMMON -( POWER OFF RESETS THEM)
    #500-#999 ARE COMMON (STAY ACTIVE DURING POWER OFF)
    O1234
    G00G90G20G40G97G99
    #500=2.000(MATERIAL OD)
    #501=1.900(TURN DIA.)
    #502=-1.000(Z TURN LENGTH)
    N1(TURNING TOOL)
    G28U0.W0.
    G0G97S2000T0101M3
    M8
    G0X[#500+.1]Z.100(MATERIAL DIA.+.100)
    G1Z0.F.005
    G1X-.06
    G0Z.05
    G0X[#501-.05](TURN DIA. -.05)
    G1Z0.F.005
    G1X#500,C.03(TURN DIA WITH CHAMFER.)
    G1Z#502(Z TURN LENGTH)
    G1X#500,C.03(MATERIAL DIA. WITH CHAMFER)
    G1Z[#502-.05](MOVE FOR CHAMFER)
    G0X[#500+.1](CLEARANCE MOVE)
    G0Z-.1
    G28U0.W0.
    M9
    M01
    I would also include some safety's to avoid some crashes if the data is wrong
    IF[#500LT1.75]GOTO9000(SMALLEST OD.)
    IF[#500GT2.500]GOTO9000(LARGEST OD)
    IF[#500LT#501]GOTO9000(TURN DIA LARGER THAN MATERIAL)
    IF[#502GT0.]GOTO9000(Z LENGTH IS POSITIVE)
    N9000( DATA. OUT OF RANGE)
    Feb 2006
    992
    Quote Originally Posted by Ms88 View Post
    Look at RCS60 give you example, it pretty much write one program for a family part and assign movement axis with variables you want.
    The best way to learn is trial error.
    May 2007
    1003
    I'm late to the party so you should already have it figured out. I've got both books mentioned by rcs60. The book by S. K. Sinha is the one you want.
    Let me know if you still need help. I've written several master programs for families of parts. It isn't hard once you write the first program. This is the type of programming I love to do. Consider using macros to control each diameter and to control any possible taper on an O.D. (or I.D.). That way you just put a value in a variable with no need to go into the program and make modifications. Incremental moves for chamfers are your friend.
    .010 x 45 degree chamfer at the face
    G1 X[.9456+#500]Z0F.005
    G3U.0268W-.0056R.019F.002
    G1U.0164W-.0082
    G3U.0112W-.0134R.019 (X1.)
    G1X[1.+#501]Z-1.25F.004
    U.03
    Say you were also turning a 1.375 diameter on the part that also needed a .010 x 45 degree chamfer. Simply cut, paste and modify one value (and in this case a couple variables and obviously the final turned depth).
    G1U.0164W-.0082
    X[1.3206+#502]
    G1U.0164W-.0082
    G3U.0112W-.0134R.019 (X1.375)
    G1X[1.375+#503]Z-2.5F.004
    U.03
    B controls are a pain. Our last 2 EMAGS purchased have them. Previous EMAGS and all our other Fanuc controls are C. For a B control:
    G1X[.9456+#500]Z0F.005
    G91G3X.0268Z-.0056R.019F.002
    G1X.0164Z-.0082
    G3X.0112Z-.0134R.019 (X1.)
    G90G1X[1.+#501]Z-1.25F.004
    X[1.3206+#502]
    G1X.0164Z-.0082
    G3X.0112Z-.0134R.019 (X1.375)
    G90G1X[1.375+#503]Z-2.5
    Jun 2015
    4154
    q x uz
    q x1.375 (c0.01)
    hy such that becomes input, and postprocesed for whatever you wish / kindly
    May 2007
    1003
    Quote Originally Posted by deadlykitten View Post
    q x uz
    q x1.375 (c0.01)
    I think your words got frozen because some letters are missing. Must have broken up and dropped to the ground. I don't understand much of what you said.
    I am aware of putting on chamfers with 'C' (or radius with 'R'), but never have done it for the same reason I never learned to use G41/G42. I was told not to when I first started as my programs had to run on any of our lathes. Most were old enough not to be able to use that kind of programming.
    To the best of my knowledge 'C' will not swing a radius at the beginning and end of a chamfer. The chamfer is made in a straight line. I always swing a radius on chamfers to avoid a burr being kick back which often happens when the insert gets a little worn. If a burr is made when swinging a radius, then you know the insert is shot.
    BTW, I was told in 2008 that the company wanted me to use MasterCam for all my programming. They wanted a newbie to be able to call up the part and change the post processor so it could be run on any of our lathes. Personally I don't do that to run on a different lathe. It is easy for me to make the necessary format changes to go from one lathe to a different one. I have a bunch of Macros in the editor or I do a Ctrl H to make global changes.
    Previously I just used MasterCam to save myself from using a lot of trig. I might have driven a tool or two and copied the output into my program. The rest of the program was manually written.
    MasterCam doesn't do Macro programming worth a damn. LOL.
    Jun 2015
    4154
    q3 (r0.003c0.01r0.003) x1.375
    q3 x1.355 (r0.003) x1.375u45
    (r0.003)
    q3 x1.355z0 (r0.003) x1.375u45 (r0.003)
    q3 (r0.003) x1.375z0.01u45 (r0.003)
    May 2007
    1003
    (r0.003)
    Thanks. I can see that I need to revisit a programming manual from one of our new lathes.
    May 2007
    1003
    Quote Originally Posted by g-codeguy View Post
    EDIT: Also deadlykitten I believe you work with Okuma controls. I may not have this flexibility with Fanuc controls. Afraid I haven't checked into this yet. Been swamped and it isn't looking any better in the foreseeable future. If I didn't post from home, I wouldn't be posting. And that's after my wife goes to bed.
    Jun 2015
    4154
    you mean posting cnc programs, or posting on cnc zone ? in both cases, seems a bit weird
    why don't you post both from work, and have more free time ?
    May 2007
    1003
    I mean posting on cnczone. I'm doing a lot of posting (Mastercam) at work. We are always short-handed so I not only trouble shoot, but help set up occasionally. I'm the only programmer for 26 lathes.
    Jun 2015
    4154
    you are a bit busy just hang on, a little bit more
