586,116 active members*
3,288 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Buy Inductive Sensor 4F-2U(0625)
    Post Buy Inductive Sensor 4F-2U(0625)
    Hello, i need help with my cnc lathe, it stopped recognizing the turret movement so i can't change tools, it spins but the signal is not recognized. i dont know if the inductive sensor F4-2U(0625) its broken or it may be something else?
    Feb 2008
    521
    Re: Buy Inductive Sensor 4F-2U(0625)
    Most inductive sensors are pretty bullet proof due to predominately being used in 'harsh' environments. Hook the two wires up to a digital multi meter set to millivolts and with rotation you should see a rise and fall in voltage - this should determine if the sensor is working and maybe the problem lies elsewhere?
    Jan 2018
    1516
    Is this one?.
    https://www.aliexpress.com/item/3280...644d6105ocyYUu
    Price not too bad .
    I'd replace it.
  1. Question about inductive sensor wiring in series
    By Azalin in forum CNC Machine Related Electronics
    Last Post: 07-31-2021, 12:54 AM
  2. Inductive Sensor
    By R2D3 in forum PlanetCNC
    Last Post: 11-17-2019, 05:47 PM
  3. Inductive Proximity Sensor Limit Switches
    By clembrant in forum DIY CNC Router Table Machines
    Last Post: 01-09-2016, 06:57 AM
  4. Wiring an Inductive Proximity sensor for TB6560. How?
    By Azalin in forum Stepper Motors / Drives
    Last Post: 11-11-2015, 09:19 PM
  5. probotix to inductive prox sensor
    By xkadet in forum CNC Machine Related Electronics
    Last Post: 04-14-2009, 04:00 AM
