586,042 active members*
3,796 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Laser fill missing fill always in the same place (see pictures)
Results 1 to 7 of 7
Threaded View
    I have a chinese 60 watt laser (1200mm tube) The machine was purchased in April 2021 and has had very light usage.
    I use the Cohesion3D LaserBoard and lightburn software. I installed an mA Meter. I have my laser power (on machine not software) at 45 and the mA meter never goes over 20ma
    Water cooling CW5000
    I have have used this no more than 75 hours in total (this is a really small part of my business which I wanted to increase for Christmas)
    So very little use
    This has been working like a charm, no problems at all until yesterday
    It seemed to be missing parts of a fill (always the same parts) and the meter at some points showed no current at all even at 20% which is what its normally run at
    I have added a couple of picture for you to look at. Not sure why but the line lasering seems ok but fill is just not working correctly
    I really do not know much about electrics so if thats an issue I need to be very careful
    I am not sure if this is a tube issue (hopefully not) a power issue or a software issue
    The last line on the picture did not complete due to I turned the extraction air on and it stopped the laser
    Kim
    Attached Thumbnails Attached Thumbnails 20211107_112443.jpg   20211107_075912 copy.jpg   20211107_090924.jpg
  1. Fiber laser hatch fill not smooth
    By bigape in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-29-2021, 02:03 AM
  2. base for converted x2 to fill or not to fill?
    By davesharps in forum Benchtop Machines
    Last Post: 01-24-2019, 04:20 AM
  3. Reversing the fill image or getting the negative fill in TM CAD???
    By lordhelemt in forum Uncategorised CAD Discussion
    Last Post: 07-03-2015, 03:35 PM
  4. Replies: 2
    Last Post: 05-21-2013, 05:52 PM
  5. Help me fill in the gaps with laser cutting
    By jcizek in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-31-2012, 02:50 PM
