586,655 active members*
4,001 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > What size chipload and depth of cut based on diameter of endmill?
Page 1 of 2 12
Results 1 to 20 of 38
    Jan 2007
    869
    Greetings all,
    I've been doing a fair amount of playing with my new Syil X3, and let me tell you, it's been seriously exceeding my expectations. It's a great machine and i'm glad I made the purchase.
    My problem however is coming in with me trying to do some milling with a 1/8" endmill. Frankly, i'm going a little nutz and have managed to destroy 4 - 1/8" endmills in 1 session.
    There are 2 bits of information I am looking for.
    1) How do I determine what size chipload I am going to desire for a particular diameter endmill?
    2) How do I determine how deep of a cut I can make based on the diameter of a particular endmill?
    I'd like to find information for all different sized endmills. I've been doing OK with anything bigger that 1/8", but a lot of them are guesses as well. I have been googling, but haven't found the right information or haven't found exactly what i'm looking for. Basically, I need a good rule of thumb to follow.
    I have found a few things that give high and low ranges, but it doesn't make sense to me why or in what situation you would use the high or low range.
    Any help would be most appreciated!
    Thanks much,
    Wade
    Feb 2007
    246
    Try running about .001 to .002 IPT (inch per tooth) for a feed rate, should be good for the machine. As for depth a good rule for HSS endmills is half of cutter dia, so for a .125 cutter about .0625 should be about the most you should go for.
    Spindle speeds for HSS in mild steel should be about 100 SFPM(surface feet per minute). So for a 1/8 cutter it should be like this
    4 x 100(sfpm)
    1/8 (dia)
    If you are kinda new to machining the Machinery Handbook is a great buy, worth the $100 for sure.
    What happened to the endmills that went bad on you?
    Hope this helps a bit, anymore questions just fire away.
    Live free or die
    Jan 2007
    869
    See, that's the problem. I understand this in Inches per Minute, the IPT completely confuses me. Also, i'm doing the machining in Aluminum.
    On the cut I was doing I was doing, it was .05" for a depth of cut, my RPMs were 3500 and my IPM was 2.5". I used the feed/speed calculator in Mach3 for the calculation with a chipload of .0005" and it actually came back that I should be able to do a 3.0 IPM, but I figured i'd be safe and ramp it down to 2.5 IPM.
    As far as the endmills, well, the cutting part of the end mill just twisted right off and stuck in the aluminum. There wasn't any heat and I was blowing a light stream of air on the part to keep the chips clear. After shutting down the machine and removing the broken part of the endmill, there was no evidence of melted aluminum, hence my confusion about what I am doing wrong.
    Wade
    there would be enough friction for the aluminum to get a little sticky and break your tool , spray a little wd 40
    also your speeds are painfully slow
    at 3500 rpm you should be running around 10.5 ipm safely
    Jul 2005
    12177
    Quote Originally Posted by wwendorf View Post
    .....There wasn't any heat and I was blowing a light stream of air on the part to keep the chips clear. After shutting down the machine and removing the broken part of the endmill, there was no evidence of melted aluminum, hence my confusion about what I am doing wrong.
    Wade
    When machining aluminum with a small cutter I think it is essential that some coolant or cutting fluid is used. A readily available substitute is automatic transmission fluid; just brush or spray it on along the cut line; nothing fancy is needed.
    Aliminum has a tendency to adhere to the cutting edge and form a build up. This combined with the chips often becoming very thick as they come off the tool means the flutes on the cutter get jammed with aluminum; no melting has occurred the metal has just been deformed.
    The figure you give for depth of cut is good being a bit less than 1/2 the diameter; your feed per tooth was a bit high, I would suggest 1% to 2% of the cutter dia. i.e. 0.001" to 0.002", with a four flute cutter a smaller chip load is better because there is less space in the flutes for chips.
    I would expect using coolant and a feed of 0.002" per tooth with a two flute cutter should give you good results.
    EDIT: misplaced my decimals in the feed per tooth calculation.
    Feb 2007
    246
    RPM X #of teeth X feed per tooth
    Higher feed and lighter depth should help with coolant or cutting fluid of some sort.
    Live free or die
    Apr 2005
    12
    aluminum
    I would add that you allways use a coolant.lubricant(kerosene works great) and all ways climb mill. I have been amazed at how fast I can mill aluminum while climb milling. If you are using a longer end mill than a stub length, I would cut down on the first cut depth to 1/4 cutter dia. (.030) to cut down on torsial deflection.
    Jan 2007
    869
    If I had a coolant setup, i'd definately be using it. Unfortunately, I don't have the room to build a collection system around the mill, hence why I am trying to get the proper chipload on a 1/8" endmill. I also can't deal with the mess of coolant going all over the place right now. I use the shop for woodworking as well as metalworking.
    If I can get the right chipload and speed down, then I'm hoping that I can remove material at the correct speed so that the heat is being removed as I cut.
    Also, if I go faster than about 2IPM, then my endmill is basically history in the first few seconds. I don't see how I can go faster with a 1/8" endmill. Please note that with anything bigger, I have no problems going faster. 6IPM with a 1/4" is pretty good I think, especially running without coolant.
    Wade
    PS. I am considering the fog buster coolant system however.
    Mar 2005
    1673
    Quote Originally Posted by masterblaster View Post
    If you have to much backlash in your system you will break the cutters even faster or spoil the part if you climb mill.
    Also I didn’t notice you mention if the cutters are HSS or STC; they should be HSS.
    John
    Jan 2007
    869
    I'm using HSS tin coated. Also, what do you mean by too much backlash? How much is too much?
    Wade
    Jan 2004
    3154
    Your cutter extension (out of the collet) needs to be as short as possible.
    IMO HSS is WAY too flexible, The cutter grabs, flexes sideways, overloads, and SNAP!
    My rule of thumb is never use HSS under 1/4" cutter diameter. Small carbide cutters are almost the same cost.
    Otherwise cut your DOC by 50% and increase your feed an extra 20 - 30% (over proper calculated).
    www.integratedmechanical.ca
    Nov 2006
    7
    haslagl
    I been a toolmaker for 30 years and depth of cut is always a subject that no one, it seems, can give you a formula for. There are so many variables. I cut 1018 cold roll, thicknesses from 1/8 thick to 3/16 thick. I am using carbide cutters ranging anywhere from 1/16" to 1/8" diameter cutting slots. As the other gentlemen suggested using WD40 or kerosene is very important. Aluminum's nature is to stick to the cutter. Air will not stop this. You need to use some form of a lubricant. An air mister is good but it blows the lubricant into the air. I use a hand sprayer with WD 40 and shoot the lubricant at the cutter. Your choice is one of those two for starts if you don't or can't use flood. I am assuming your Syil is a small CNC. Make sure you are using a two flute cutter if you can with a high helix. They make cutters specifically for aluminum. Carbide is better as mentioned and the cost for 1/8" carbide is not that much different. Enco, basstool.com, are two good places to look for carbide at low prices. Their cutters are pretty good. I cut cold roll steel with those small carbide cutters at depths of about .030, feed rate from 8 to 10 for 1/8" and a spindle speed of around 5500 rpm. You should know the formula for finding cutting rpm and feed from what other individuals have given you. Aluminum has a SFPM up to 850 for HSS and 2020 with carbide for finding your cutting speeds, feed per tooth from .0015 to .0080". This is from the Machinery's Handbook. I would use values of about 1/4 of the maximums for feed. The depth of cut is then the big player here. I have always been told that 1/2 the diameter of you cutter is what you should figure, but if you are buzzing into your material at 40 inches you will snap it off. You will need to start on the low end of the feed and work your way up. You may want to start your cutting depth at .030 and go deeper as you find what’s working. Slow feeds and deep cuts or shallow cuts and high feed rates – make notes and see what you can get away with. You may want to start your cutting depth at .030 and go deeper as you find what’s working. Slow feeds and deep cuts or shallow cuts and high feed rates – make notes and see what you can get away with. If you are machining for a living you will have to find a happy medium with your cutting rate that is cutting good and making you a profit. Again the depth of cut is a big issuer so often. There is not a real formula for it such as you have with speeds and feeds. In many shops the tendency is shifting towards high speed machining using high feed rates, high rpm's, and light depth of cuts. But we are talking about 20,000 rpm spindes also and expensive machines. Sorry the long reply but I hope I could help. My phone number is 573-897-0700 - I own my own shop and I am a machine tool instructor.
    Mar 2005
    1673
    Sorry for posting the wrong information I read that as 8mm end mill; I will look more carefully in future.
    Haslagl
    While we have the attention of an experienced machinist. What are your thoughts as to STC or HSS coated when used to mill aluminium? Keeping in mind we are talking small hobby size Milling machines or at best light duty production. Also taking into account lower RPM range of around 3000 max.
    John
    Nov 2006
    7
    haslagl
    John - Coatings are fine - they just drive up the cost of the cutter. I not an expert in coatings but I do know that TIN coatings do make the surface super hard. I was a little skeptical of this until I saw first hand what it did for punches and die blocks in a production dies. It really does extend the life of tools and tooling. There are new coatings on the market that are better yet such as the TICN and ALTIN which are very good coatings. They are better than the TIN coatings in certain applications. Most shops will call up cutter representatives that they buy from and have an applications specialist discuss the proper cutting tools to use. But once end mills become dull and if you should decide to have the end mill sent out for re sharpening then the coating is gone on the cutting edge. I do believe that there are some re sharpening services now that will recoat the end mills. HSS cutters are fine - they just don't have the life of carbide, but then again if you drop a carbide cutter it damages much easier than HSS. In cutters 1/2 and bigger you can now get cutters that use indexable carbide inserts which are up front more expensive but in the long run are cheaper than carbide end mills. Carbide inserts can take a lot of abuse and wear better than carbide end mills. I realize you are limited on spindle speed and because of that I would stay with HSS. Carbide is designed to run at very high RPM's but the choice is yours. There is nothing wrong with running carbide. It will last a lot longer than HSS. One other thought - I do know that carbide cost is getting high because of China, so HSS might be a good alternative when looking at purchase cost. One thing someone else wrote about was tool flex - carbide end mills don't flex like a HSS cutter can. Well I hope I may have helped you.
    Mar 2005
    1673
    You certainly have helped me and I appreciate your time and knowledge. From my reading I have come to believe HSS is a better choice for aluminium because it keeps a good cutting edge longer. Also as soon as a STC cutter makes its first cut the edge will fracture because it is so brittle consequently requiring more cutting force.
    I have also read that TiAIN coating should not be used with aluminium but is right for harder metals and TiCN would be the correct choice?
    John
    4826
    FWIW, standard 1/8 endmills tend to be a bit long in the flute for slotting with. Stub length is about right for heavy duty use.
    If you have the know-how and a grinder, it is possible to shorten a standard endmill, and regrind the end flutes so it will center cut. I typically only try this offhand with a 2 flute, because there is not enough room to work around the end of a 4 flute as easily. I recommend a good CBN wheel with a sharp edge reserved for this type of work, as it will grind a lot of tools and still maintain that sharp corner for a very long time.
    Mar 2007
    4
    Cutting Speed
    Hello,
    To determine cutting speed and feed I recomend that you go to www.onsrud.com . They sell endmills. They have lots of data on the how and why of speed and feeds. They have several useful free manuals that will help you. I am the programer for 8 cnc routers. I use the web site when i get a diffrent material to machine. All you have to do is match up the size, type of endmill and material to be cut and the site will tell you the speed and feed rate. Good luck
    Ray Mahlberg
    Nov 2006
    7
    haslagl
    John
    Yes end mills with the TICN coating are recommended for cutting aluminum.
    I have not seen HSS end mills with that coating on them but then I haven't seen everything. Just a note: I remember reading an article in a magazine call American Woodworking. It was about HSS wood cutting saw blades and carbide tipped wood cutting saw blades for table saws, radial arm saws, etc. Under a microscope the HSS steel was sharp to a razor edge while the carbide tipped blade even thought properly sharpened there were microscopic chips in the cutting edge. Point being that the carbide cannot was not able to have the superior cutting edge that HSS gives. But you sacrifice the hardness of carbide. Good luck.
    Mar 2005
    1673
    Quote Originally Posted by haslagl View Post
    John
    Thanks again I always appreciate the experienced members jumping in to help us amateurs (speaking for myself there and not intended for other posters here). You just can’t beat experience imo.
    Regards,
    John
    Jul 2005
    12177
    ....Under a microscope the HSS steel was sharp to a razor edge while the carbide tipped blade even thought properly sharpened there were microscopic chips in the cutting edge. Point being that the carbide cannot was not able to have the superior cutting edge that HSS gives. But you sacrifice the hardness of carbide. Good luck.
    Slightly to the side of the topic but relevant I think.
    This difference in superior edge sharpness with HSS is why it is often better to use HSS when machining plastics; in particular the softer plastics such as UHMW polyethylene, Nylon and Teflon. These materials can 'flow' around the not-so-extremely-sharp cutting edge on carbide tooling.
    The rigid plastics like Delrin can machine quite well with carbide, expecially the micrograin carbides that are available for aluminum. These micrograin carbides can perform quite well even on the softer plastics and they become practically essential with the filled plastics. It does not matter too much whether the filler is something like glass fiber for strength or graphite for lubrication they are both abrasive and cause rapid wear on HSS tools.
    Also plastics with compounds included as flame retardants often require carbide because the flame retardant can be abrasive.
Page 1 of 2 12
  1. Please help me identify AMS endmill
    By johnbirch in forum MetalWork Discussion
    Last Post: 04-07-2007, 09:22 PM
  2. Optimum Endmill Size
    By thackman in forum Syil Products
    Last Post: 03-17-2007, 05:01 AM
  3. X3 base size or minium bench size
    By kenrc in forum Benchtop Machines
    Last Post: 02-04-2007, 01:50 PM
  4. When to use slotdrill or endmill.
    By MrBean in forum MetalWork Discussion
    Last Post: 03-21-2005, 06:16 AM
  5. Ballscrew size -vs- project size
    By Alan T. in forum CNC Machining Centers
    Last Post: 10-19-2004, 02:53 AM
