586,042 active members*
3,743 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Fair strong DIY CNC machine (Wood and Aluminum) - Design Idea
Results 1 to 7 of 7
    Jun 2021
    4
    Hi Everyone, I have decided to try build my own CNC. What I am looking for is to build a fair strong platform that works with wood mainly and aluminum sometimes. I found a really nice design on internet (I lost link to owner but all credit goes to him), and I started modifying his design to better idea until reached initial design as per photos.
    Items planning to use:
    - 2.2kw water cooled spindle
    - NEMA 34 stepper (4.0N.m / 3.6mH) for all axis
    - SFU1605 ball screw for all axis
    - HGR20 linear guide rail for X and Y axis
    - HGR15 linear guide rail for Z axis
    Workable Area (so far):
    Y > 790 mm
    X > 648 mm
    Z > 125 mm
    Looking forward for your feedback and idea. thank you in advance.
    Jul 2018
    6339
    Re: Fair strong DIY CNC machine (Wood and Aluminum) - Design Idea
    Hi Rab -
    1) For that size spindle I would use 20mm cars vs 15mm on the Z. The bottom cars on the Z take a lot of beatings and need to be strong. Especially if you want to take full advantage of 2.2Kw. oK for a 1.5Kw
    2) The base screw bearings mounted on the cantilevered flat plate is a candidate for vibrating. Either mount it lower or web it some how
    3) The large N34 Z motor again is on a cantilever and is a candidate for vibrating stiffen it or support it better
    4) the construction extrusion bolted to the back of the gantry is way too inefficient. Since your cutting up plate make a plate box gantry way better
    5) Its not ideal chopping so much metal out of the Z plate for the drive nut. Its usual and better to do the trench in the gantry so the tool plate is as stiff as can be
    6) The bearings behind the spindle need to be further apart the 2.2kW spindle if used to its max will generate a lot of moment on this area. Especially since you have picked 5mm pitch for the screws, these will move small trucks quite easily so forces will be large
    7) Its coming along... Peter
    Jun 2021
    4
    Hi Rab -
    Thank you Peter,
    1) i will change to 20 mm
    2) i will try redesign to make it better
    3) i think i found better mount for N34 motor
    4) now this important, if i do plate box gantry, will not be heavier?? the extrusion is bolted too with the cantilevered flat plate (not showing in photo up) will not be good?
    5) am working on that, i really need as you said to reduce a lot of metal in Z
    6) i will wide the distance between them.
    I have important question, the SFU1605 ball screw. I have been told they will make the movement way slow on X and Y axis with N34 motors, do you suggestion i go for 1610 or 2010 maybe?
    Apr 2004
    141
    You would want to go with a 10mm lead screw to optimize speed vs a 5mm lead screw. You really do not lose any usable resolution unless the rest of your machine is really robust and tuned in to use that resolution.
    Even with my current 25mm 4 start ball screw, with N34 motors, I am limited to 350 ipm max Rapids running with 78v feeding the controllers, but stay well below that max speed as a safety margin.
    John Z
    Sent from my SM-G991U using Tapatalk
    Jun 2021
    4
    Quote Originally Posted by JohnZ View Post
    John Z
    so do you suggest i stay with NEMA34 and change to 10mm lead screw, or go to closed loop NEMA23/NEMA24 and stay with SFU1605?
    I found NEMA23 3N.m (425 oz.in) 3 phases and NEMA24 4N.m (566 oz.in) 2 phases with good price so money not that big difference now
    Apr 2004
    141
    I would say to go with the 10mm pitch with either motor frame size. This provides the following benefits...
    Lower RPM of the ballscrew at both cutting and rapid movements. Reduced whip on those long screws. Keeps the stepper motor up in its higher torque curve, minimizes missed steps.
    Cons - reduced resolution per step. This is really only a con when your entire machine can actually use that resolution under cutting forces. Let's look at your 10mm lead with a typical 200 step per rotation motor at 1/8 microsteps. Each microstep gives you 10mm / 200 / 8 or 0.00625mm (or about .00025") of motion. Your gantry plus all other mechanical components combined will flex orders of magnitude more than this. Reduced linear thrust. This might be an issue, but if you look at the torque curve of your motor, then compare the motor torque at the RPM you will be cutting at with a 10mm lead, then compare the torque at 2x that RPM for a 5mm lead, thus usable thrust will be remarkably similar. I know that this is very oversimplified, but the bottom line is that the 10mm lead will be better for your use case than a 5mm lead.
    Regarding N34 vs N23... I'll just say that I regret buying large N34 motors. I would have been much better off with N23 motors with a lower inductance, and more usable torque at the RPM's I actually use. I wasted time and money going from a 12v controller, to 24v, then to 80v controllers, then from generic Chinese controllers to Gecko controllers. I'd have been much better off with good N23 motors and good controller's from the beginning.
    John Z
    Go with 2010 screws, and find some Nema 34's with much lower inductance, less then 2mH. Run them at 60V.
  1. Replies: 0
    Last Post: 12-24-2019, 02:47 AM
  2. Recommended DIY baseline design for two-spindle wood and plasma cutting CNC
    By ryanjg117 in forum Open Source CNC Machine Designs
    Last Post: 06-28-2019, 11:13 AM
  3. design CNC machine for hard wood
    By moris.el.is in forum DIY CNC Router Table Machines
    Last Post: 08-18-2015, 04:53 PM
  4. My first DIY CNC machine design please need advice
    By Graphicman in forum Open Source CNC Machine Designs
    Last Post: 12-05-2013, 03:27 AM
