586,062 active members*
4,548 visitors online*
Results 1 to 6 of 6
    Oct 2020
    10
    How to test a vfd
    Can you tell me how to test a vfd? I have an exiting vfd that won't turn the spindle very fast. It's turning like 25 rpms. That's what it looks like. But I don't know if it's the spindle, vfd or the settings that has the problem. Please help......
    I have a 110v 2.2kw HY HUANYANG VFD and spindle. TIA
    Sent from my SM-G781U using Tapatalk
    15362
    Re: How to test a vfd
    Quote Originally Posted by jpmreno View Post
    120v and 2.2Kw is a bad combination to start with, yes it will most likely be a programing problem, but if you have the VFD Drive connected to a 120v outlet then it will not be able to get enough Power / Current to run this 2.2Kw spindle motor
    So need to know what Parameters you have set, and how you are powering it with your 120v supply.
    Mactec54
    Oct 2020
    10
    I've had it running by 110v for four years now. I just rebuilt my machine and had to change some settings on the vfd and it started doing this low rpm spinning. I was trying to get mach3 to turn on the spindle and operate the rpms. I should have left it alone. Is there a self diagnostic program I can run?
    - - - Updated - - -
    15362
    - - - Updated - - -
    Where do you live that has 110v power supply ???
    No there is no self diagnostic program in these VFD Drives.
    What Parameters did you change ???
    I can give you the correct Parameters but need to know what you changed.
    Do you have a list of what Parameters are set ???
    Mactec54
    Oct 2020
    10
    In the US hereare my pd settings.
    15362
    IN NA the Power supply is 120v / 240v not 110v / 220
    Can not read the Parameters can you make a PDF file of them, that should fix it.
    Mactec54
  1. Replies: 1
    Last Post: 10-09-2019, 01:25 AM
  2. Milltronics VM-17 vfd spindle enable, spindle test.
    By plane captain in forum Milltronics
    Last Post: 02-10-2016, 04:36 PM
  3. test VFD output
    By Mikescnc in forum Gecko Drives
    Last Post: 12-01-2015, 07:25 PM
  4. PMDX-107 to WJ200 VFD Cannot get test mode to work for settings.
    By Contract_Pilot in forum Spindles / VFD
    Last Post: 07-21-2015, 06:49 AM
  5. Replies: 18
    Last Post: 09-15-2014, 02:09 PM
