586,071 active members*
3,756 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma Thru Tool Coolant Line Filter Clogged
    Jan 2014
    10
    Hi Everyone,
    Could someone point me in the right direction to get a new filter for this? This is on the thru tool coolant pump. The filter housing is a MASUDA 10MPa line filter, model F-FPME06-20S-036-X. See attached pics.
    My machine is an Okuma MA-600HB
    Appreciate your help!
    Kyle
    Attached Thumbnails Attached Thumbnails 20211111_120106.jpg   20211103_211320 (1).jpg
    Mar 2009
    1982
    Re: Okuma Thru Tool Coolant Line Filter Clogged
    I would try to clean the filter if it is not damaged yet.
  1. Haas VF2 coolant line clogged.
    By K_Labs in forum Haas Mills
    Last Post: 08-27-2014, 05:02 AM
  2. *NEWBIE* Power Line filter (Transformer vs. Filter)
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 09-26-2009, 02:36 AM
  3. Coolant Exiting Hoses keep Getting Clogged
    By JWB_Machining in forum MetalWork Discussion
    Last Post: 01-14-2009, 06:02 PM
  4. Replies: 4
    Last Post: 03-11-2008, 07:43 PM
