586,036 active members*
4,343 visitors online*
Results 1 to 10 of 10
    Am i crazy or will this work?
    So im not new to building machines, i retrofitted my onefinity with a ATC spindle and got 2.5 cubic inches MRR in aluminum.
    Now im ready to move into steel(i dont have a need but I'm sure i could get work pretty quick and i have some parts i personally would like to make.)
    I bought a second machine, a HDM. I bought it because i run my onefinity lights out and i could fill it with more parts machining aluminum.
    https://shop.carbide3d.com/products/...39378702532669
    That saidddddd, i love the idea of these cheap machines running and mistakes being cheap.
    Im thinking what if i convert this thing with servo spindle and use it for steel.
    Ill probably use Masso like my Onefinity and i definitely want ATC. so im wondering if this configuration will work. Keep in mind, i made this model in 20 minutes and its for nothing other than concept.
    My Main concern is speed on the Z axis as thats part of the equation of MRR.
    The idea would be to use a belt to drive from the Servo to the mounted spline linear bearing, this turns the shaft down to the spindle cartridge and allows the spindle to move up and down with the spline bearing moving along the shaft.
    There would probably be another bearing to capture the shaft above the one transmitting power and rollers to prevent the spline linear bearing from moving up and down when the spindle cartridge moves.
    Then for the ATC, i would also keep the air cylinder off to the side and making a lever to transmit the power down onto the spindle cartridge, just to keep the weight off the Z axis.
    Im sure its not this easy and im missing stuff so help me see the light if im crazy.
    https://www.mcmaster.com/61145K172/
    https://www.mcmaster.com/61145K115/
    Re: Am i crazy or will this work?
    Very creative, looking for your update.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Nov 2013
    4372
    how much current does the 3.8kW servo draw? 2.2kW is considered a practical maximum for a domestic single phase supply.
    Even with a power factor of 0.6, which is optimistic for a servo, 3.8kW suggests 27A at rated power and potentially 54A at 200% overload.
    Craig
    @joeavaerage
    looks like they are only pulling 13.5 amps so my guess is you just caught them lying.
    https://www.aliexpress.com/item/3287...50244776%22%7D
    Nov 2013
    4372
    13.5 x 230 =3105 W, well short of 3.8kW. My guess is that the current stated is the output current per phase.
    Single phase input current can be calculated:
    3800 /230 = 16.9A, but this assumes unity (1.0) power factor whereas 0.6 power factor is optimistic:
    16.9 / 0.6 = 27.5A.......and remember the power factor could be lower, lets say 0.5....then:
    16.9 / 0.5 =33.8A.
    With a 200% overload your 3.8kW servo could draw as much as 67.6A.....and that will trip most, if not all, domestic circuit breakers.
    Low power factor is a plague of servo drives and VFDs. It can be improved but at some expense.
    Craig
    16.9 / 0.5 =33.8A.
    Craig
    Thanks Craig, you're the man.
    ill go with something more along the lines of this, unless you have a better suggestion.
    https://www.aliexpress.com/item/3305...48bd4177qZxbOX
    Nov 2013
    4372
    the smaller unit you linked to will demand less current from your supply, and that may help.
    What most people don't realise is just how much current a servo drive or VFD can draw. If you are aware of the power requirements and are prepared to have an electrician fit a larger
    cable/breaker/and socket then no trouble. If however you plug your machine into a regular 10A or 15A socket when your spindle digs into some heavy going the breaker will trip.
    We shifted our business premises last week. We had an electrician install a new three phase circuit, three new 20A single phase circuits and run a 16mm cable in preparation for
    my new 2.8kW servo based single phase spindle motor It will have a 50A D curve breaker when equipped. I will still have power factor correction, as much for electrical noise abatement
    as input current reduction. I've yet to decide whether I'll go for a line reactor or build my own active power factor correction module.
    I have not used Lichuan servos, they have abysmal documentation and have no set-up and tuning software. I use Delta B2 series servos, they are about 25% more expensive but well
    worth it in my opinion.
    Craig
    Craig
    well Craig, you were right. Lichuan is trash and was a waste of money. Its got zero drift and errors out regardless one day but then works the next day.
    got pretty far and now i cant get the servo tuned. Sooo im going to spend twice like an ******* and buy a Delta B2. Hopefully i can sell this lichuan.
    appreciate the heads up on B2. doing research rn for which one to get for my motor and then im going to order
    @cncmakers001 heres what it looks like not mounted.
    Jan 2018
    1516
    Craig
    I've not tried it but lichuan do have what they call 'debugging' software. That's supposedly software to do with the setup of the drive.
    Will have to try it out when I get back onto it.
    I've got the driver disc and tx cable.
    But yes. I'd only use the Lichuan as a spindle. Delta for the axis. Easy to get cables for delta too.
    I just cannot decide whether to use 200w or 400w on the axis of a G0704 sized bench mill.
    Quote Originally Posted by dazp1976 View Post
    i tried to use their debugger but it sucks and it wouldnt work.
    i just want a good strong servo that does 3k rpm and has the most torque i can get for under 25lbs and runs off single phase
    why lichuan gotta make it so hard.
  1. Am I crazy?
    By swaxolez in forum Joes CNC Model 2006
    Last Post: 01-31-2021, 02:24 AM
  2. Am I crazy to consider this?
    By NoBars in forum Fadal
    Last Post: 12-20-2015, 01:53 AM
  3. Crazy Z
    By hmoore01 in forum Bridgeport / Hardinge Mills
    Last Post: 06-30-2015, 10:18 PM
  4. Crazy one motor two screw idea, can it work?
    By rlrhett in forum DIY CNC Router Table Machines
    Last Post: 04-15-2008, 01:03 AM
  5. Crazy move, almost work.
    By slp_prlzys in forum CNC Machine Related Electronics
    Last Post: 04-12-2005, 07:47 AM
