586,069 active members*
3,554 visitors online*
Page 4 of 4 234
Results 61 to 64 of 64
  1. #61
    Jul 2018
    6339
    Re: My First CNC Build
    Hi BW - Warning technical stuff ahead .....Timber is a bit different to metals and plywood is different again because it is a laminate. The main delta is that it has poor shear stiffness as a material vs metal (isotropic material). If you do FE and tell the FE its an isotropic material you are way over estimating its shear stiffness.. So the FE deflection will be less then the real deflection unless you dial back some of the numbers or do an orthotropic analysis.
    The outer geometry (the box) is responsible for its bending and torsional stiffness. So a box is great except where the loads come in and out of the structure. In a cnc gantry this is a moving spot (the saddle) so using internal webs means the beam will be different local stiffness at the webs and where there are no webs. If its an open box the corners are what provides the resistance to lozenging. If the walls are thin then the corner stiffness is low and the section lozenges from either torsion or direct shear. This is a dilemma as some of these effects are neglected in std linear FE (1st order elements) and definitely neglected in manual calcs using beam equations unless you understand second order eqns and that's really complex past my pay range. I use linear and non linear FE techniques that can account for the shear deflection (second order elements)... I've done a lot of timber boat structures to survey and they are picky.
    You mention strength but strength is not how to think about it. The stress in these structures is really low and its not a strength issue its a stiffness issue. These things will never break but they do deflect and every part deflects a little bit adding up to potentially a lot of global deflection.
    So a filled box or holy box solves the local shear stiffness problem. Gantry beams are not "long" beams or what's called a flexure beam. if you look at the flexure beam equations they are applicable if the shear deflection can be neglected. A beam is considered short if its length is about <10x its major dimension. So a 100x100mm gantry only needs to be 1000mm long and the flexural equation is incorrect as the gantry is shear dominate. Most gantries are shear dominant with some flexure so the local shear stiffness is really important if you want to design at that level. This is the main reason construction extrusions when filled with epoxy granite do better as this type of extrusion really sucks in shear stiffness. This is called shear flow as well.
    Getting back to timber. Timber is in fact closer to a foam then a solid. Most timbers are about 50% air and they are highly oriented. That's why they are stiff along the grain and not stiff across the grain. Ply and LVL and mass timber fix this to a degree. If you use FE its worthwhile setting up a deflection test and model that and tune the FE to the test. Then at least you will have the bending correct.
    if as you say the box is predominantly torsion and its material has poor shear stiffness aka timber then std equations will let you down in predicting the stiffness. This is because the section will lozenge, lose its shape and be inefficient in resisting the torsion if the box is too thin. If you look at trees they are very thick compared to their diameter this indicates something. Trunks are put under very large torsion and bending and they optimise to this. Being alive they don't like breaking.
    So in summary a "box" is not always the solution for a gantry or a "beam". Its convenient but does have some pitfalls if its too thin. Thin is relative to the material and to the local loading. Happy to do some actual FE to explain if needed. Its hard to generalize on some of this, need actual geometry and conditions to figure out solutions. The best approach I have so far to take advantage of plywood is to laminate aluminium sheet on the outside. This leverages AL stiffness and the timber fills in the middle for some light shear transfer/ shear stiffness... Peter
  2. #62
    May 2014
    261
    My bad if I said strength I meant stiffness. While strength is important stiffness is king in CNCs.
    I have heard people mention that wood is full of air especially when talking about particle boards, or boards that have been reconstituted. I'm sure Chris will quickly work out what needs to be stiffened up the moment he starts using the CNC.
    I made many of my original parts out of plywood just to get started, and later used the CNC to cut fresh parts out of metal. There was a significant difference in rigidity. I had some serious chatter issues back in those early days and the Council was called to check out what I was doing the machine screamed that much.
    If my post is missing an 'nt you might have to add it yourself.
  3. #63
    Jul 2018
    6339
    HI BW - Wood or timber is mainly cellulose which has a density of 1500kg/m3. Since ply is about 700kg/m3 this means its about half air and some glue. Its fibres are entangled which means their connections are more like plastics long chain linkages then metal which is more like Lego blocks. Plastics can disentangle and elongate whereas metals slip over each other... This also means timber has a lot of internal hysteresis as its internals are not well connected so are damp. All good for machine use. But timber is hydroscopic and it swells and shrinks relative to the relative humidity. This can be slowed down by resin coating or aluminium skinning. I do a lot of infusion and have infused many types of woods to turn them into tooling board or harder stuff. Its quite easy to fill them up under vacuum and double their weight ie its 50% air by test as well.
    Cellulose has a modulus of 25Gpa so agrees with 0.5x25=12.5GPa which is about what good plywood is along the grain. Ply can be stiff as its rotary peeled and full of glue and cross laminated etc... Its a great material I think the only draw back for DIY machines is its moisture instability which can be fixed. But ultimately its not stiff enough vs metals to be a true contender to cut metals as you have found.... Peter
    https://en.wikipedia.org/wiki/Cellulose
  4. #64
    May 2022
    This is not just a post about my first CNC build; it's a post about my first mistakes and lessons learned. I'm going to show you some of the problems that caught me off guard and hopefully you can avoid them or at least be prepared if they happen to you. I prefer you to check https://stacylash.com/mink-eyelash/ and gain lashes for your eyes. With a very affordable price tag, the mink lashes could be yours in quality and looks of real mink fur. So I figure it's still building and it's close enough. With that being said, let me explain what happened with my first CNC build.
Page 4 of 4 234
  1. New Build/First Time Build - BAM CNC
    By BAMIN in forum DIY CNC Router Table Machines
    Last Post: 09-07-2017, 07:25 PM
  2. CRP PRO 48x24 DIY Custom Build. First CNC Build.
    By OrangeClockwerk in forum Avid CNC
    Last Post: 11-06-2014, 11:58 PM
  3. Build Thread - 80/20 5X10 Woodworking CNC Build
    By jsantos in forum CNC Wood Router Project Log
    Last Post: 08-20-2014, 03:15 AM
  4. Going to build my 1st cnc. Matching needs to parts... build journal
    By oldman4m80s in forum DIY CNC Router Table Machines
    Last Post: 04-26-2013, 03:20 AM
  5. Wetland CNC Build (WOODEN BUILD)
    By jasoneule in forum CNC Wood Router Project Log
    Last Post: 01-09-2013, 01:18 AM
