586,071 active members*
4,374 visitors online*
    Aug 2016
    35
    RFQ Drilled Aluminum bar
    3/4" x 3/4" x 24" aluminum bars (2 needed) drilled as per sketch - holes are drilled 1/2" deep and hole size is so a #8D finish nail can be snuggly inserted into each (#39 drill?).
    Aug 2016
    35
    Re: RFQ Drilled Aluminum bar
    Better make it 1/2" thick bars drilled thru. Would have edited request but apparently cannot(?). Also still cannot find out why it keeps saying I am posting from a mobile device when I am not or edit some of my profile info!
    Feb 2018
    21
    Is this job still open?
    Sent from my SM-N975U1 using Tapatalk
  1. 7075 bar stock turned and center drilled
    By advert in forum RFQ (Request for Quote)
    Last Post: 11-04-2016, 04:41 AM
  2. RFQ: 250 pieces 5052 aluminum bar stock + 2 dowel pins
    By ahk199 in forum North America RFQ's
    Last Post: 02-14-2013, 02:08 AM
  3. 20MM round bar drilled and tapped
    By bp238 in forum RFQ (Request for Quote)
    Last Post: 07-22-2011, 12:58 PM
  4. Hex Bar Stock turned and drilled/tapped
    By ez3022 in forum Employment Opportunity
    Last Post: 10-01-2010, 12:04 AM
  5. RFQ: UHMW Cut to length and drilled
    By mrbaseball in forum Employment Opportunity
    Last Post: 11-10-2005, 12:34 AM
