586,055 active members*
4,273 visitors online*
Thread: PD settings
    Oct 2020
    10
    PD settings
    I need some help yall. I have the HY Hanyang VFD and spindle. I use 120v and the rpms are manually set. Here is my PD settings.
    Attached Files Attached Files
    15362
    Re: PD settings
    Quote Originally Posted by jpmreno View Post
    You may have to do a Factory Reset if you have changed any other Parameters, as this is the only Parameters you need to get running.
    Huanyang Mactec54
    2.2Kw 110v 400Hz Water Cooled / Air Cooled
    PD000=0 ( 1 For Parameter Lock )
    PD001=0 (1 For Remote Control)
    PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control )
    ( J1 Also Needs to be set for Remote Terminal Control 1-2 jumper connection )
    PD003=400
    PD004=400
    PD005=400
    PD006=5
    PD007=20
    PD008=110 (Motor Rated Voltage )
    PD009=15
    PD010=15
    PD011=120 ( 100 Minimum Setting For Water Cooled Spindle )
    PD013= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
    PD014 Acceleration=8 ( Adjust to suit)
    PD015 Deceleration=8 (Adjust to suit)
    PD023=0 ( Forward Run Only )
    PD041=8 ( Carrier Frequency up to 10 Max for these Spindle motors)
    PD120=100 ( Stall Prevention )
    PD141=110 ( Motor Rated Voltage )
    PD142=9 ( Motor Max Amps 2.2Kw Spindle 9 amp )
    PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM) 3,000= (24,000)
    PD070=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
    PD072=400
    PD073=120 ( 100 Minimum Setting Water Cooled Spindles )
    PD174=11 ( To Be Set to the VFD Drives Max Rated Output Amps )
    Mactec54
  1. Replies: 6
    Last Post: 04-18-2021, 01:00 AM
  2. cv settings
    By electric2u in forum Machines running Mach Software
    Last Post: 01-27-2011, 03:19 AM
  3. help with settings
    By asdasd in forum ArtCam Pro
    Last Post: 07-06-2010, 05:27 AM
  4. Mach3 CV settings vs. G-100 Plugin CV settings
    By Bfarn in forum Machines running Mach Software
    Last Post: 12-17-2008, 05:45 PM
  5. Settings
    By piedpipertraps in forum DynaTorch
    Last Post: 10-15-2008, 11:30 PM
