586,104 active members*
3,252 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Slave proble...possible solution question...
    Hello, I have a slave problem posted here: https://www.cnczone.com/forums/mach-...-software.html
    I am wondering if I just connect both motors to the Y axis from my control board....? Im thinking there isnt enough power to run both motors from one plug?
    Does anyone know if I am able to do this or if it would even work or will create other problems?
    Nov 2008
    643
    Re: Slave proble...possible solution question...
    You can run two steppers off one drive but why do you need to? Stepper drives are inexpensive.
    Nov 2008
    643
    So I have a machine where two steppers are wired to one stepper drive but the steppers are connected to the ends of the same belt.
    In the case of a slaved Y axis you normally have two separate belts or lead screws. If you can not control each motor then you won’t be able to home the machine properly. Meaning any twist or racking of the Y axis that occurs will remain. These machines also have two Y axis limit switches which MACH3 works with quite well.
    3d printers sometimes wire both Z stepper motors to the same drive. They can get away with it because they don’t go far and no loads to cause the racking.
  1. Safe slave axis question
    By skubajon in forum Mach Software (ArtSoft software)
    Last Post: 08-10-2015, 06:30 PM
  2. proble
    By h.khoshjavar in forum Community Club House
    Last Post: 01-24-2014, 02:53 PM
  3. Mach 3 slave axis question
    By msimpson99 in forum Mach Software (ArtSoft software)
    Last Post: 02-13-2012, 05:51 PM
  4. Question about slave stepper
    By jzurek in forum DIY CNC Router Table Machines
    Last Post: 03-05-2011, 01:48 AM
  5. Slave Stepper Question
    By mlk1950 in forum DIY CNC Router Table Machines
    Last Post: 11-27-2010, 03:18 AM
