586,106 active members*
3,171 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Need help ....Fuling Vfd, steel enclosure and small steps
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    15362
    Re: Need help ....Fuling Vfd, steel enclosure and small steps
    Quote Originally Posted by rjwims View Post
    Could you please give an an example of 1.732 single to 3 phase perhaps based on my 8.8 per phase 3.2kw motor
    You mentioned Trick wiring. Can you explain
    Also, does the attached chart look accurate?
    thanks again
    I don't think your 3.2Kw spindle will be 8.8 per phase
    Trick wiring, well it is not for everyone, so I only post about it when it is needed. at this point you don't have a need.
    Motor name plate Amps or FLA x 1.732= the required input Amps for Single Phase Supply to 3 Phase, plus 125% for cable and Breaker size, you can work it out from this PDF
    Mactec54
  2. #22
    Oct 2021
    24
    What do you figure my spindle will draw per phase, under 8? Manufacturer says that 120% of rated for 8 sec is max recommended.
    Unless I push it hard, I don't think I'll ever see much over 20 amps in the single phase side.
    3.2 kw @240 v (my supply voltage
    3.2/.24 X1.25 = 16.7 amps
    Distance from service to VFD is under 6 feet
  3. #23
    15362
    If the name plate amps are 8.8A then it should be around 3A per phase
    Mactec54
  4. #24
    Oct 2021
    24
    It's as clear as mud.....lol
    I'll get it eventually, I hope
    thanks again, you are a wealth of knowledge
Page 2 of 2 12
  1. Seting up a Fuling DZB VFD
    By GerryG in forum Spindles / VFD
    Last Post: 06-18-2020, 08:56 AM
  2. Fuling DZB300 series VFD and Spindle
    By BJM737 in forum Spindles / VFD
    Last Post: 12-30-2019, 04:28 PM
  3. Fuling d130m vfd
    By ezajohn in forum Spindles / VFD
    Last Post: 11-16-2014, 03:42 PM
  4. Need help: Help me identify this VFD FULING
    By rajshinai in forum Spindles / VFD
    Last Post: 08-27-2014, 08:29 AM
  5. Fuling to Huanyang VFD switch
    By futureform in forum Phase Converters
    Last Post: 05-06-2013, 01:49 PM
