586,104 active members*
3,470 visitors online*
Results 1 to 5 of 5
    Question My End Mills Keeps Breaking
    Hi everybody,
    So i have 3 Blue Elephant 6090 Router machines and i have been working with those machines for 2 years.
    My machines got 2.2 KW spindle and 600x900 (mm) grid and im using air cooling for the parts and water cooling for the spindles.
    A new problem comes up.
    I have made some GCodes for aluminum 6061 milling and its work fine until some point that it doesnt.
    I have a few part that im working on for the past 3 days, after 6 parts or so, the machines was working fine and the end mills keeps running great, and suddenly they start breaking.
    I didnt changed anything, same end mills, same feeds and speeds, same machines.
    What could cause this problem?
    Nov 2013
    4375
    Re: My End Mills Keeps Breaking
    does the broken endmills show Built-up-Edge (BUE), that is to say aluminum stuck in the flutes?
    Aluminum is 'sticky' and prone to BUE, and this is especially so if the chips are not cleared from the cutzone and are recut.
    Many people use a continuous air-blast, either with oil mist or without, to blow the chips out of the cutzone. I use flood cooling, and it does cool but really
    its all about removing the chips so they don't get recut.
    Craig
    thank you for your reaply.
    Actually no, there is no any aluminum that stuck on the edges.
    im using 1 flute end mills for that kind of milling, the remove the chips perfectly.
    I also have a vacuum cleaner on the spindle with a costant air blast down ther.
    Haven't cut aluminum, but I had issues using tiny end mills on wood when the toolpath wasn't smooth, and then when some of the rollers needed adjustment.
    I'm thinking in your case there could be some issue that's causing the end mill to move in a jagged fashion and take a bigger bite than it can handle. Check all things moving for any play - guides, motion components... could even be some interference that's causing your motors to skip steps / overstep, etc.
    Nov 2011
    261
    Dear*Blue*Elephant*Customer,
    Have a nice day! This is BLUE ELEPHANT CNC MACHINERY CO., LTD.
    We are very sorry that there is a problem with your machine. In order for our after-sales engineers to know about your machine configuration as soon as possible to solve your machine problems, please help to provide your machine pictures, S/N number, or the sale name who contact you. After you provide the above information, our professional after-sales team will contact you immediately.
    Please give us your contact information such as whatsapp or email adress. Or you can contact us by sending email to [email protected].
    Any reply will be highly appreciated.
    Sincerely,
    BLUE ELEPHANT
    E-mail: [email protected] Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
  1. CNC router started breaking end mills after an accident.
    By Ivan-Ivanov in forum DIY CNC Router Table Machines
    Last Post: 05-28-2018, 07:04 PM
  2. Breaking end mills, need advise
    By BNX in forum Tormach Personal CNC Mill
    Last Post: 02-24-2013, 01:54 PM
  3. Keep Breaking 1/8" End Mills
    By nfrees114 in forum MetalWork Discussion
    Last Post: 08-07-2009, 11:38 PM
  4. machining through breaking end mills
    By woffler in forum Work Fixtures / Hold-Down Solutions
    Last Post: 06-13-2009, 04:11 PM
  5. Running carbide end mills in side-lock end mill holders
    By Cory in forum MetalWork Discussion
    Last Post: 01-14-2008, 02:55 PM
