586,117 active members*
3,394 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Having problems with my new Scroll air Compressor
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    May 2013
    167
    Re: Having problems with my new Scroll air Compressor
    It's been a long process trying to get this compressor working correctly, but its finally working great!
    I added a Acme Electric model A3015K0310B transformer ( Buck Boost Transformer ) to help get my voltage set closer to the safe voltage that the compressor was looking for.
    The transformer ran around $600
    I contacted the manufacture of the transformer and they gave me the correct wiring configuration to get our output voltage at aprx 234v
    There are various wires inside the transformer and depending on how they are hooked up with get you to the desired voltage. ( the wiring configuration they gave me wasn't in the manual )
    You can either raise your voltage or lower it depending on what wires you use on the inside.
    This has now solved the issue of the over voltage alarms, and it has also solved the issue of the contacts chattering when they engage.
    So we are good to go...
  2. #22
    15362
    Quote Originally Posted by kentdesautel13 View Post
    It's been a little journey, but more expense than was needed though, once you had committed to the transformer, you had to make that work, it looks like the compressor is wired then for a 230v supply and NA 240v was just a little too much inrush for the cooling fan.
    Mactec54
Page 2 of 2 12
  1. Air Pump/air compressor for laser engraving/cutting machine
    By lasertube in forum Commercial Laser
    Last Post: 04-30-2018, 04:59 PM
  2. Replies: 0
    Last Post: 04-06-2017, 12:38 AM
  3. Replies: 0
    Last Post: 03-20-2017, 08:31 PM
  4. Replies: 0
    Last Post: 12-22-2014, 03:24 AM
  5. Problems with a 480V three phase rotary air compressor
    By Eric MFG in forum Maintenance DIY Discussion
    Last Post: 07-10-2012, 02:26 AM
