586,700 active members*
2,743 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > 4.5kw Chinese electric fan cooled ATC spindles. Anyone here have one?
    Mar 2017
    926
    A family member wants to buy my next spindle as a gift and these low end ATC spindles are within budget.
    https://www.ebay.com/itm/26531113303...Bk9SR6KBht6pXw
    Does anyone here own one? I can't find many reviews.
    I'm trying to decide if it's worth taking a chance vs getting another Colombo or PDS MTC spindle (or a used Colombo ATC one).
    It turns out that I'm doing more tool changes than I thought so ATC would help on a second machine... but only If I can trust it to work properly...
    15362
    Re: 4.5kw Chinese electric fan cooled ATC spindles. Anyone here have one?
    Quote Originally Posted by Goemon View Post
    Just remember it is inexpensive, for a spindle like this, the front of the spindle looks quite thin at the nose for a 30 Taper, this is most likely to cut down on inertia, it also seems it has max torque at 12,000 RPM, which may suit you if you cut a lot of aluminum Etc.
    Mactec54
    Jun 2021
    105
    Perhaps contact them as well to discuss expected run out, unless I missed it when reading through the provided Ebay descriptions.
    Mar 2017
    926
    Quote Originally Posted by TMToronto View Post
    Even if they put a number I wouldn't trust it. In my experience, you guys are a far more reliable source... assuming I can find someone here who owns one.
    Even the "reputable brands" can be hit or miss for entry level products.
    Mar 2017
    926
    Yeah I've been going around in circles in my head on this. It does look like it has a small shaft given the bearings it uses. This slightly more expensive 30 taper one uses larger bearings:
    https://www.ebay.com/itm/25467203167...3ABFBM_uvJ-6lf
    I'm not sure how much it matters for a 3-4nm spindle though. It's not powerful enough for anything heavy-duty even if the shaft was thicker.
    Even if it looked perfect in the pics it wouldn't give me any confidence.
    The issues I'd be more worried about with a cheap Chinese spindle are noisy low quality bearings, a poorly cut taper and the motor burning out / starting a fire as soon as it's too late to return it...
    I'm OK with it hitting peak power at a lower speed. I can't see any disadvantage. I'd want one that hit peak power at 6000rpm (or lower) if it was an option (at this price point).
  1. Replies: 8
    Last Post: 09-29-2021, 11:03 PM
  2. Electric Fan Air Cooled Chinese Spindle
    By dakmon in forum Spindles / VFD
    Last Post: 07-01-2021, 04:25 PM
  3. Which of these spindles should I get? 2.2kw vs 2.5kw ATC
    By Gojira in forum Chinese Machines
    Last Post: 08-23-2019, 06:32 PM
  4. Chinese 1.5kW, water cooled spindle and controller.
    By Pader in forum Drilling- and Milling Machines
    Last Post: 10-20-2017, 02:07 PM
  5. chinese spindle strip dowm 1.5Kw air cooled
    By Mick Gannon in forum Uncategorised MetalWorking Machines
    Last Post: 10-09-2014, 11:11 AM
