586,067 active members*
4,749 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > HURCO HDD issue Dos utilities disk
    Apr 2010
    I recently purchased a 1995 BMC 30HT/M mill and so far all works great.
    I've noticed the HDD is making some noise that doesn't sound like it has much life left. I tried to clone the drive onto an SSD, but it's not working (I'm using Windows 10 and used a generic cloning program). I've attempted to alter the BIOS to match the original HDD, but it still doesn't want to work. I've followed various threads regarding HDD failure and replacements and all have resulted in the same thing, a big fat no-go. For now I put the original HDD back in and the machine is working.
    Everything I've read mentions formatting and copying the files to the new HDD via a DOS Utilities Disk. This is the only disk that didn't come in the folder with the machine disks. I have the Software Ver. 1.54 disk 1&2 along with the Ultimax Ver. 1.53 Machine config disk 1 of 1. -side note, anyone know of a software upgrade for this? The machine has the 24 tool-change umbrella if that helps.
    Does anyone have a copy of the DOS Utilities disk or link to where I can obtain it from? Is it available somewhere? I've searched and haven't found it.
    Any help will be greatly appreciated. Thank you.
    Apr 2010
    Re: HURCO HDD issue Dos utilities disk
    anyone??
    Jun 2008
    1104
    Before you do anything, put a floppy disk in the machine, format it and save the config to it. I can make hard drives for that machine as ?i used to work for Hurco (I quit earlier this year after nearly 39 years).
    Jun 2005
    1730
    Like Bloke said copy absolutely everything on the old drive to another media, I would use a USB flash drive large enough to hold everything.
    Cloning the old drive should have worked? What operating system is on the old computer?
  1. Hurco SSM Clone Disk
    By maxlee00 in forum HURCO
    Last Post: 10-12-2021, 03:14 PM
  2. Hurco BMC30 system/HDD problems
    By PPG78 in forum HURCO
    Last Post: 06-25-2021, 09:33 AM
  3. Cadkey DOS utilities
    By SPJ in forum Uncategorised CAD Discussion
    Last Post: 02-10-2018, 09:33 PM
  4. Hurco Disk Option
    By Rulunney in forum HURCO
    Last Post: 11-14-2010, 04:48 PM
  5. Hurco disk drive
    By MadPickinSkills in forum HURCO
    Last Post: 09-12-2010, 07:10 PM
