.0001" or .01mm
You most likely will want to keep 'the jaggies' under control during interpolated motion (ie., circular cuts and 2 axis straight angular cuts). The lower the resolution, the more that stair-step type errors show up.
Going the metric way actually gives you a wider tolerance range, but in a practical sense, you don't want to fight with a CAM system of any sort that must attempt to round numbers off to the nearest .0003 or .0004"
