586,119 active members*
3,607 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > "Missing Left Expression Bracket" Error in latest version
    Aug 2011
    999
    I was trying to run a surface scan with the latest version (11/15/21) and got this error message (screen shot below).
    Strangely, the offending line is actually not 33 but rather 39 and it looks alright to me, no missing bracket in the script.
    Then I ran the same command on another computer with the June version (although only in simulation mode) and did not get the error.
    After update to the November version, I also get the same error in simulation.
    Not sure what changed but I am kind of stuck.
    Any ideas how to fix? Or is that a new bug?
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
    Mar 2017
    1312
    Re: "Missing Left Expression Bracket" Error in latest version
    I'll fix this.
    Mar 2017
    1312
    Until next version you can modify script and use ROUND instead of ROUNDUP.
    I was fixing ROUNDUP function and I made stupid mistake,
  1. Replies: 3
    Last Post: 09-11-2020, 05:12 AM
  2. Replies: 6
    Last Post: 09-15-2019, 09:35 AM
  3. Replies: 3
    Last Post: 04-20-2019, 08:20 PM
  4. Heidenhain "Angle Reference Missing" error
    By Lugy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-13-2017, 06:59 PM
  5. "Arm Must Be Left" Error
    By smokediver576 in forum Fadal
    Last Post: 03-17-2013, 04:04 PM
