586,052 active members*
3,940 visitors online*
    Jacking Puck RFQ
    Hi all,
    First time posting.
    I'm looking for a quote to manufacture the following quantities:
    40 jacking pucks
    80 jacking pucks
    120 jacking pucks
    I need the puck, the bolts, and the plate the bolts would thread into to secure the jacking pucks to the vehicle.
    I will need to get these made from 6061 aluminum, I need them color anodized, and then have my logo and some text engraved on the side of puck and the bottom too.
    I'm prepared to take care of anodizing and engraving using another provider, but prefer a one stop shop if possible.
    Not sure if it's acceptable to post a link here to an Amazon page showing a jacking puck similar to what I want. I will try here:
    Dewhel Jack Pad Adapter Billet Anodized Red Aluminum Floor Jack For Corvette C7/C6 Premium bolt on Jack Points - 4 pack https://www.amazon.com/dp/B07BNHNG7J/ref=cm_sw_r_apan_glt_fabc_BAE2PBMGZS18K2W8CB4Y?_en coding=UTF8&psc=1
    David
    [email protected]
    Jan 2008
    60
    Re: Jacking Puck RFQ
    Sending you a PM
    Jan 2008
    60
    Sending you an email.
  1. vac puck used on an adjustable clamp
    By woodman08 in forum Gorilla CNC Machines
    Last Post: 04-27-2017, 03:25 AM
  2. digitizing from paper with a puck.
    By mvcorrea in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-26-2008, 03:08 AM
  3. Jacking Screw for Tapered Dowel Pins
    By dkaustin in forum Tormach Personal CNC Mill
    Last Post: 03-24-2008, 11:54 PM
  4. Rubber hockey puck?!
    By abomb55076 in forum Material Machining Solutions
    Last Post: 02-27-2008, 06:56 PM
  5. tablet puck as pendant?
    By foamcutter in forum CNC Machine Related Electronics
    Last Post: 03-04-2005, 01:32 AM
