586,973 active members*
2,970 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Good Resource on Timing Belt Information
Hybrid View
    Jun 2018
    9
    Hows it going guys,
    Anyone have any good resources on timing belts ? I would like to design a 2:1 gear system with HTD belts but having a hard time figuring out relationship between belt circumference and pulley distance. Is there a rule of thumb or something.
    Thanks !
    15362
    Re: Good Resource on Timing Belt Information
    Quote Originally Posted by umfan110 View Post
    Hows it going guys,
    Thanks !
    This should give you what you need, just select the type of timing pulley profile, metric/ inch, number of teeth and ratio, or a desired center distance.
    https://sdp-si.com/tools/center-distance-designer.php
    Mactec54
    Jun 2018
    9
    Thanks !
  1. No timing belt available for lathe
    By rusel in forum Uncategorised MetalWorking Machines
    Last Post: 02-03-2019, 05:46 PM
  2. How to match Timing pulleys and timing belt? (noob question)
    By cdesantis01 in forum Linear and Rotary Motion
    Last Post: 02-10-2017, 01:27 AM
  3. Replies: 0
    Last Post: 12-31-2016, 04:45 AM
  4. What is a timing belt and pulley ?
    By ynneb in forum FAQ of DIY CNC Machine Building
    Last Post: 02-18-2011, 01:38 PM
  5. timing belt instead of screw
    By Ed Williams in forum DIY CNC Router Table Machines
    Last Post: 10-28-2009, 01:27 PM
