586,051 active members*
3,825 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Need help on how to better machine relieved surface (old X2 version)
Results 1 to 7 of 7
    Jan 2007
    311
    Not always but enough to be a pain, I end up with parts that have 2 z-heights within a contour. Like a link with a raised boss on one end that matches the contour on 3 of the 4 sides and the remaining side is the one that goes off towards the other end of the link and that surface is lower than the boss
    Normally I'll run the contour on the outside of the part then deal with the relieved surface
    I can't use facing to clear off the relieved surface or it cuts into the boss on that area
    If I use pocket with island (which I normally end up doing) it leaves a thin wall around the outer contour of the part which sometimes breaks off and I'm worried might get wrapped around the cutter or something
    I'm looking for some way to have it use the surfacing type tool-path where it will go over the edges and at the same time NOT go over the edges that define the raised boss
    Here's a typical example, the surface in white is what I'm referring to
    Attachment 473110
    Just looking for the forest through the trees.
    Keep in mind I'm using an old version of MC (x2) so there might be some new tool path out there that I don't have
    Thanks for any ideas
    Jan 2018
    1516
    Re: Need help on how to better machine relieved surface (old X2 version)
    Adaptive clearing on the white section would prob be best.
    That's what I use if I have a raised ridge that needs leaving.
    Jan 2007
    311
    I don't think that's an option on my version. I'm drawing an extra profile around the lower part that comes off where the boss meets the outside contour now and using pocket and then a contour to clean up the shoulder but it's another step in the process I'd like to be able to skip if I could
    Thanks for the suggestion
    M
    Nov 2007
    361
    Quote Originally Posted by Mooser View Post
    M
    Did u try using open pocket ? Or y not just draw the toolpath that u want the tool to take
    Jan 2007
    311
    I'm more or less drawing the path now by adding some lines that run off of the proper shoulder and go around the outside of the part enough to ensure the cutter clears off everything, it's just a bit of a pain to add each time (1st world machinist problem)
    I'll look again at the open pocket but honestly it usually doesn't seem to work each time I try to use it but maybe it's time to revisit it and see exactly why
    Thanks for the reply
    M
    Dec 2008
    3109
    You still on this....
    You are best to just contour, create new geometry up the centre area for a tool to have no offset ( tool cuts on centre, you create/adjust the geometry that is to form the path, no lead in/out), AND, then contour the un-machined raised area with comp active
    Jan 2007
    311
    Those parts are long gone but it's just that "type" of situation seems to come up more often than not and I've always done it one way or another type of thing. The center line contour might work for skinny part like these, I'll have to keep that in mind
    M
  1. Where to get welded steel frame stress relieved?
    By aaltman in forum DIY CNC Router Table Machines
    Last Post: 02-13-2020, 02:10 AM
  2. powermax 45 machine version vs hand version
    By landmark in forum Hypertherm Plasma
    Last Post: 02-14-2010, 11:13 PM
  3. stress relieved stock
    By yoopertool in forum CNC Swiss Screw Machines
    Last Post: 07-16-2009, 07:11 AM
