586,219 active members*
3,406 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > 2002 Milltronics SL10/05 Series A CNC Turning Center
    May 2021
    4
    Got a new machine in today and it was dead on arrival. Not sure exactly what is wrong with this machine but its got the Centurion 6 control on it and the whole machine seems in very good shape. It used to be used in a community college so it has only seen limited use. Anyway, The screen just pops up blue and says "no video input". So I whipped out the multimeter and did some testing on the Clock Battery on the CPU. It read .230V so that's dead. So I installed a new battery but I also noticed the LEDs for the CPU Backplane aren't all lit up. So I double checked the power supply and I got +5V, -5V, +11.75V, and -11.75V. But when I check the Backplane Volt that leads to the CPU its only +5V that works. All other voltages are dead. So something is stopping the voltage to the CPU? Anyone got any ideas just trying to set this up and its been a bit of a headache. Thanks!
    Mar 2019
    14
    Re: 2002 Milltronics SL10/05 Series A CNC Turning Center
    David,
    Have you called Milltronics service directly? Very good phone service from them in my experience.
    They will also send you all the digital manuals for your machine including electrical diagrams upon request.
    I cant help with your question but I am sure you will be able to get it solved.
    Eric
    May 2021
    4
    Thanks for the Reply,
    We contacted Milltronics and had us send the computer back in to them. They repaired it for around $500.
  1. HAAS SL10 CNC TURNING CENTER
    By orion_engineers in forum SERVICE FOR CNC-MACHINES
    Last Post: 06-07-2021, 06:04 AM
  2. Required ROM IC's Data for FEMCO CNC Turning Center With Fanuc 10T Series
    By james anderson in forum Wood Lathes / Mills
    Last Post: 12-12-2012, 09:49 AM
  3. Replies: 3
    Last Post: 05-23-2011, 06:16 AM
