586,395 active members*
2,920 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > DIY 4 Axis Hot wire - Plans converted to G-Code and cut on CNC
Results 1 to 1 of 1
    Dec 2021
    So after looking around I decided to build a U.S. variant of RC Keith's 4-axis foam cutter. I took his drawing which you can purchase from him for $5 (a bargain) and converted it to g-code and cut all the MDF parts on an Industrial CNC 4x8 foot router table. I used Illustrator to turn off un-needed layers and then laid the parts out for a 2'x4' sheet of MDF from Home Depot. Illustrator exported a DXF which I opened in CamBam and set up my cuts and pockets before generating the g-code. Mach 3 sent the g-code to the Industrial CNC (at work, not mine). I'm in for about $400 for everything needed to complete the machine. I should end up with 20" vertical and 27" front to back with the width being adjustable out to about 1 meter.
    Here are a few pics of the CNC routing process, will post more build pics as I go. His build is well documented, search for RC Keith and you will find him. Only modes I made to his machine is to use 3/8" rod and T-nut instead of the metric rod and nut he specs, and I extended the vertical arms 6.5" to give me 20" 0f vertical. Everything was sourced from Home Depot and Amazon.
    Enjoy,
    Jason
    Attached Thumbnails Attached Thumbnails IMG_0707.jpg   IMG_0708.jpg   IMG_0709.jpg   IMG_0710.jpg
  1. DIY CNC Hot Wire Cutter
    By koko97 in forum CNC Wire Foam Cutter Machines
    Last Post: 11-07-2015, 02:15 PM
  2. What 4 axis CNC hot wire cutter to buy?
    By Snowy in forum CNC Wire Foam Cutter Machines
    Last Post: 12-08-2011, 01:18 AM
  3. Hot Wire for 3 axis CNC
    By huntycnc in forum CNC Wire Foam Cutter Machines
    Last Post: 10-19-2007, 11:32 PM
  4. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
  5. cnc hot wire plans wanted
    By chris69randy in forum CNC Wire Foam Cutter Machines
    Last Post: 03-12-2005, 03:03 AM
