586,058 active members*
4,522 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Need advice mounting Z assembly/Dewalt 611
Results 1 to 6 of 6
    Dec 2018
    112
    I purchased this Z assembly and the Dewalt DWP611 but now I am having trouble trying to figure out the best way to mount them.
    Are there any mounts or adapter plates out there for the Dewalt DWP611 (69-71mm) that will bolt up to this Z assembly? Or do I have to fabricate something myself?
    I thought about reversing the Z axis so I can mount the Dewalt to the 30150 aluminum extrusion but I still cannot find a way to do it without fabricating something. Plus the Z axis would be very heavy that way.
    Would appreciate any help.
    Feb 2005
    750
    Re: Need advice mounting Z assembly/Dewalt 611
    Found this on ebay:
    https://www.ebay.com/itm/28361478741...UAAOSw-jBdfajr
    I am sure you will probably have to drill and tap some holes, but at least you dont have to bore out a 70mm hole.
    Halfnutz
    Dec 2018
    112
    Yeah I found a few mounts for the DWP611 but I do not see any bolt on solution. Looks like I will have to make some kind of adapter plate. All the added mounting plates that go on these CNC's don't seem to be the best design. I would think that keeping everything as tight/close to the axes mounting points would provide less stress/leverage on that axis.
    I found these as well:
    Seems like this one would be a little heavy. But I like the design feature of being able to tilt the spindle/router without trying to shim things.
    I am curious how these thinner clamps would hold up when working on something like aluminum? Do people double up these clamps or just use a single?
    Nov 2012
    1267
    Quote Originally Posted by Sray View Post
    No question you would need two of these to have any rigidity.
    Nov 2008
    643
    I fabricated the Mount.
    The main part of the clamp is a pair of steel sheets wrapped around the body and tac welded. Band clamps hold it tight. I converted from MIG to TIG after this so the welding is crude, but it works. The mount can be made from steel found in local stores.
    Dec 2018
    112
    Thanks for the input guys! I guess I will need to add a mount to my list of things I need to make.
  1. Looking for Mounting Brackets for Dewalt 618 on an Ooznest CNC Workbee.
    By Jayson_2016 in forum RFQ (Request for Quote)
    Last Post: 05-07-2020, 09:12 PM
  2. Advice please on toolholders and mounting
    By Rabs2014 in forum Uncategorised MetalWorking Machines
    Last Post: 03-23-2016, 05:02 PM
  3. Need Advice on Machine Assembly
    By GeorgeIoak in forum DIY CNC Router Table Machines
    Last Post: 06-18-2013, 04:15 AM
  4. New Myford lathe - need some mounting advice
    By jeffdg in forum Uncategorised MetalWorking Machines
    Last Post: 04-29-2007, 11:54 AM
