586,103 active members*
3,013 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Tweaking the HH430 postprocessor
    Dec 2021
    I'm trying to tweak processor for Heidenhaim 430 so it would accept arcs. I've tried various entries in
    *CW_ARC_MOTION*
    *CCW_ARC_MOTION*
    etc.without success. It seems like those have not been taken into consideration at all. Maybe it is just that I haven't entered correct values as HH codes are different.
    Any suggestions how this should look like?
    May 2013
    261
    Re: Tweaking the HH430 postprocessor
    Go on the madcam website and email Joakim directly with your post question, I think this is above what most will be able to help you with here , I am just starting to wrap my head around post language
    Feb 2006
    183
    Below is a post processor for Heidenhain that works with madCAM 7.
    //MadCAM_POST_2022-02-10
    *VERSION*
    7.0_210910
    *FILE_NAME*
    Heidenhain
    *FILE_EXTENSION*
    h
    *FILE_DEST*
    c:\postfiles\
    *FILTER*
    0.005
    *OUTPUT_WIDTH*
    *OUTPUT_DECIMALS*
    *SCALE_X*
    *SCALE_Y*
    *SCALE_Z*
    *AXIS_1_CHAR*
    X
    *AXIS_2_CHAR*
    Y
    *AXIS_3_CHAR*
    Z
    *ARC_RADIUS_CHAR*
    R
    *ARC_DX_CHAR*
    X
    *ARC_DY_CHAR*
    Y
    *ARC_DZ_CHAR*
    Z
    *RAPID_MOTION*
    "lnbr" L "x" "y" "z" R F 4250 M
    *LINEAR_MOTION*
    "lnbr" L "x" "y" "z" R F "feed" M90
    *CW_ARC_MOTION*
    "lnbr" CC "xc" "yc"
    "lnbr" C "x" "y" "z" DR-
    *CCW_ARC_MOTION*
    "lnbr" CC "xc" "yc"
    "lnbr" C "x" "y" "z" DR+
    *CUTTER_REFERENCE*
    TIP
    *COOLANT_ON*
    M08
    *COOLANT_OFF*
    M09
    *RAPID*
    "motion"
    *END_SECTION*
    *RAPID_APPROACH*
    "motion"
    *END_SECTION*
    *RAPID_RETRACT*
    "motion"
    *END_SECTION*
    *APPROACH*
    "motion"
    *END_SECTION*
    *FIRST_CUT*
    "motion"
    *END_SECTION*
    *CUT*
    "motion"
    *END_SECTION*
    *TOOL_CHANGE*
    "lnbr" TOOL CALL "toolnr" Z S "speed"
    "lnbr" L M03
    "lnbr" "coolant_on"
    *END_SECTION*
    *TOOL_STOP*
    "lnbr" "coolant_off"
    "lnbr" STOP M25
    *END_SECTION*
    *PROGRAM_START*
    "lnbr" BEGIN PGM "pgmnr" MM
    *END_SECTION*
    *PROGRAM_END*
    "lnbr" END PGM "pgmnr" MM
    *END_SECTION*
    *LINE_START_NUMBER*
    It's also important to set the arc output support in madCAM options / 2D options.
    Joakim
  1. Tweaking NC after Post
    By shaunwil in forum BobCad Post Processors
    Last Post: 02-04-2017, 11:04 AM
  2. Tweaking MCX6 post
    By Chrispbrown2255 in forum Post Processors for MC
    Last Post: 03-05-2014, 10:47 AM
  3. tweaking plasma for best performance
    By bossfrog in forum Waterjet General Topics
    Last Post: 10-10-2006, 11:50 PM
  4. Tweaking a Fadal
    By krustykrab in forum Fadal
    Last Post: 05-15-2005, 06:22 AM
  5. Excellon and Gerber tweaking
    By Rhodan in forum Uncategorised CAM Discussion
    Last Post: 04-26-2004, 01:49 AM
