Hey everyone,
New to me machine, was in production 2 weeks ago. It errors out at approx Z1.8 every time. I'm doing all of this without tools in the spindle or carousel
Things I've checked:
-Manual tool change with tool in/out button works
-Full Z travel (+4 to -16)
-Verified axis is still in inches with tool setter
-Followed the ATC toolchange flow chart in the maintenance manual. Everything checks out besides I cannot find the prox switch to check manually.
--page 44: https://flintmachine.com/images/uplo...leshooting.pdf
-The value for Drawbaw in DI-DS goes to 1 after I release the tool in/out button but is otherwise 0.
-No atc fault, verified bit on DI-DS works by hand
-both ATC limit switches work via DI-DS
-Turned the 'feedback' option off in SETP with no change, put it back
-Spindle orient works
-cold start location is good. (about 0.3" between carousel and spindle)
-air pressure is good. I have it set at 100 but tried at 120 with no change
-fuses are good. Swapped k24 relay with a different one
Ran setZ, setX, and setY commands at CS location
I took a video of it happening:
https://youtu.be/BpeCfjx84Do
Any ideas?!?
Thanks!
