586,116 active members*
3,442 visitors online*
Thread: i j k errors
Results 1 to 9 of 9
    Mar 2017
    8
    i j k errors
    hello all been a while
    did a search but found nothing helpful.
    had a couple quite knowledgeable people (i thought) try to help
    but still get same error ... invalid i or j @ line n5030
    tia
    stace
    Attached Files Attached Files
    Sep 2002
    1956
    Re: i j k errors
    N5020 G91 .....
    N5030 G3 X-0.36 I-.36 J0.
    With G91 active (N5020) the end point and the center point of your circle are identical (X == I). That will not work.
    Apr 2006
    11
    Re: i j k errors
    If your using G91, then prior to line N5030 the tool needs to be positioned on the arc. Line N5030 would be G3 X0 Y0 I-.36 J0. Realize that I is saying the arc center is -.36 from the X cutting position.
    Example:
    G90 G1 X.36 Y0
    G91 G3 X0 Y0 I-.36 J0
    or
    If center is not X0 Y0
    G90 X-- Y--
    G91 X.36
    G3 X0 Y0 I-.36
    G1 X-.36
    If this helps, super. If not, just give a holler back.
    I, J, & K are always incremental values. When used in arcs or circles, they represent the incremental value of the arc start to the arc center. Most arc errors are because these values are not correct in relation to the arc start.
    Mar 2017
    8
    Re: i j k errors
    Quote Originally Posted by BobHarper View Post
    Example:
    G90 G1 X.36 Y0
    or
    G90 X-- Y--
    G91 X.36
    G3 X0 Y0 I-.36
    G1 X-.36
    thank for the quick reply i found an end mill close enough to get me out of a jam for this set... another set coming right up
    Apr 2009
    3376
    Re: i j k errors
    If you have Preditor Editor piece of cake.
    Run your machine until it errors out (note line number)
    Run Preditor and stop at line number that machine error out
    Note,as best as can,where it all took place,geometrically
    go back to CAD and you can try a variety of fixes at that particular point.
    Ex.,,erase doubles.re-organize,and a good one that happens a lot on sharp corners that are less than 90 is do a fillet.Fillet not need to be big,,but something,,say .003,,,
    good luck
    Dec 2008
    4548
    Re: i j k errors
    Quote Originally Posted by jrmach View Post
    good luck
    Hard to remember.
    I think "Make Arcs Tangential" was the geometry fix for these. But I like the duplicates thought too. I think 2 arcs in the same place causes some issues.
    But it could be a post processor setup issue too. look for 221 to 228 in the post processor.
    Mar 2017
    8
    Re: i j k errors
    I THINK I tried what u said see attachment
    Mar 2017
    8
    Re: i j k errors
    Quote Originally Posted by CNCFr View Post
    N5020 G91 .....
    can u tell me what will?
    Mar 2017
    8
    Re: i j k errors
    Example:
    G90 G1 X.36 Y0
    or
    G90 X-- Y--
    G91 X.36
    G3 X0 Y0 I-.36
    G1 X-.36
    think i did what u suggested .. see attachment
  1. errors
    By jimmy123 in forum Okuma
    Last Post: 01-10-2015, 04:40 PM
  2. Following errors
    By scrambled in forum CNC Machine Related Electronics
    Last Post: 03-20-2011, 02:37 PM
  3. Errors #1,#16,#17
    By masterfabr in forum Fadal
    Last Post: 01-14-2010, 03:55 AM
  4. Getting 2 Errors.... Someone Please!!
    By DesKitchens in forum Commercial CNC Wood Routers
    Last Post: 09-14-2009, 02:30 PM
