Re: Spindle grounding- manufacturer says to not ground
Originally Posted by
mactec54
So why post you are perthitic. (wedge)
Any Ac 3 phase motor driven with a VFD Drive produces Rotor Voltage,
a small voltage will not cause erosion of the Bearings
Perthitic ? New one on me! , is it as bad as Covid?
An AC induction motor does not produce any real voltage in the rotor shorted turns it is extremely small, there is a very high current flow however in the the single turns of a squirrel cage rotor which produce fractions of a volt.
Albert E.
