586,069 active members*
3,690 visitors online*
    Jan 2018
    1516
    spindle head BT40
    It's more a mechanical question ragrding a spindle itself.
    Are these below worth bothering with / any good?.
    Considering swapping my benchtop milling machines head for one.
    https://www.aliexpress.com/item/3283...45904801%22%7D
    Will be ran with a 1.8kw servo.
    Pulley setup will deliver max 6000rpm.
    Plan to build 10 tool ATC for it in future.
    Will it work fine?.
    Dec 2007
    41
    Re: spindle head BT40
    Firs just by looking at a bearing specs (not a precision bearing) tells a lot.
    If budget is low maybe you can swap the bearings whit high precision later if everything else is made well (?).
  1. BT40 spindle year dowm
    By Uguessedit in forum Uncategorised MetalWorking Machines
    Last Post: 09-06-2018, 03:54 PM
  2. Bt30 or bt40 spindle
    By KKamel in forum Spindles / VFD
    Last Post: 12-14-2015, 10:03 PM
  3. BT40 spindle
    By Rlimits in forum Community Club House
    Last Post: 09-08-2011, 03:22 PM
  4. Looking for spindle speeder BT40
    By bherr in forum Want To Buy...Need help!
    Last Post: 10-31-2008, 12:55 PM
  5. CT40 vs. BT40 spindle's and tooling?
    By gunsmither in forum Haas Mills
    Last Post: 01-09-2007, 05:06 AM
