586,403 active members*
2,681 visitors online*
    Dec 2006
    79
    Noob Question About Oil On New Tools
    I just graduated from my very utilitarian Taig mill vise to a snazzy looking toolmaker's vise for my mini mill. It came sealed in plastic and swimming in a small pool of oil... What is the proper thing to do? Do I just wipe it down with a rag and allow the oil to continue protecting the surface? (is it there to protect the surface, or for some kind of oil hardening process or what, anyway?) Do I scrub it down with soap and water or some type of degreaser and have a dry, but more rust-prone tool?
    Appreciate any (serious :-) advice!!
    Jim
    Jun 2006
    629
    Cleaning with Varsol is pretty standard. It will clean off the oil and leave a bit of a film!!!!!!
    "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
    Feb 2007
    246
    I usually just wipe everything off with a rag, and then spray it with a lubricant of some sort. I use something by LPS, but even WD-40 will work or just wipe a little bit of way lube on it to prevent rust.
    I think its on there to stop it from rusting before its been sold.
    Live free or die
    Aug 2007
    5
    Cleaning mini-mill
    Frank Hoose has some advice at www.mini-lathe.com After cleaning I tend to put a few drops of good grade sewing machine or 3in1 oil on a rag and wiping down the bare metal surfaces of my mini-lathe. A little WD 40 works almost as well, I'm told that over a long period of time, it doesn't give as much protection as sewing machine oil.
  1. Noob Question: Is Mach2/3 enough?
    By snooper in forum Mach Software (ArtSoft software)
    Last Post: 07-13-2006, 07:25 PM
  2. Noob question
    By PBfan in forum Uncategorised CAM Discussion
    Last Post: 07-06-2006, 05:19 AM
  3. The same noob with another elementary question.
    By maddog7 in forum BobCad-Cam
    Last Post: 05-07-2006, 02:04 PM
  4. Another noob with an elementary question.
    Last Post: 05-03-2006, 09:18 PM
  5. Ballscrew Noob Question
    By BobWarfield in forum Uncategorised MetalWorking Machines
    Last Post: 01-24-2006, 08:41 PM
