586,077 active members*
3,673 visitors online*
    Jun 2021
    4
    1100m Spindle Rebuild
    I find quite a bit of info about the PCNC spindle rebuild but not so much on the 1100m. Tormach does not provide rebuild instructions for or a diagram of the 1100m spindle. Is the bearing arrow direction the same on the 1100m as the PCNC? The 1100m spindle has a spacer tube between the inner races of the two bearing sets and the outer races of the upper bearings "float" up and down in the tube. The lower bearing is held captive in the tube with a plate and allen heads.
    Andy
    Mar 2020
    218
    Re: 1100m Spindle Rebuild
    Without knowing what kind of bearings are used in the 1100m compared to the pcnc it's hard to say. General good practice with any kind of tapered/angular contact bearings mounted as a pair on opposite ends of a shaft, is to load them towards each other though so the simple answer without any further information is yes, point the arrows the same as the diagram you posted.
    Jun 2021
    4
    HP7008c-2RzTA/P5 DBB and HP7007c-2RzTA/P5 DBB are what came out. And I purchased 7008C-DT P5 7007C-DT P5. So problem solved, I bought the wrong bearings.
    Thank you for the help!
    Andy
    Jun 2021
    4
    The correct bearings are ordered and will take several weeks to get here. Since I have assembled and disassembled the spindle several times with the incorrect DT bearing sets, I no longer consider those bearing usable. I do understand that what I did today is not correct, but it did get the mill running. Flipped over one of the DT bearings in each pair to make two sets of unmatched DB bearings. After assembling the spindle and running the machine for about 20 minutes the temperature was at 120F and climbing. Removed the spindle and took off a bit of preload. Seems to be good now.
    Attached is my first try a printing a cap to keep dirt and chips out of the bearings. I may add an upturned lip to the top and also slope the top down.
    Nov 2012
    591
    I would worry about 3D printed plastic melting, and before melting, shrinking because of the heat.
  1. Okuma LB-12 Spindle Rebuild
    By sunmach in forum Okuma
    Last Post: 10-13-2020, 01:02 PM
  2. Replies: 1
    Last Post: 02-05-2020, 11:20 PM
  3. 4020 spindle rebuild
    By Roy's cnc in forum Fadal
    Last Post: 08-29-2019, 07:53 PM
  4. spindle rebuild need some help with parts
    By powerr in forum Charter Oak Automation Support Forum
    Last Post: 05-18-2011, 06:53 PM
  5. ES-L8 Spindle Rebuild
    By big_mak in forum Okuma
    Last Post: 04-05-2009, 07:12 PM
