Hello,
I recently started working with the 4030 and I noticed some issues when using it. One problem I noticed was that the spindle RPM only responds to the physical toggle on the control board when I am manually using the machine. When I input an RPM into Candle, it does not change. How can I link up the spindle RPM to the values that I choose rather than turning a knob and guessing the RPM? (This issue is happening when I am not running Gcode, just manually driving)
Also, when I do run a design and set the RPM in the software (in this case Carveco), where can I see the actual RPMs in candle? I know that I set a value, but I just want to make sure that its actually spinning at the rate I selected while it cuts a design.
Thank you!
