586,065 active members*
4,619 visitors online*
    Fanuc error 5459
    Hi I'm working on a dugard hd1886l with a omfi controller been trying to use g68.2 and it keeps coming with error 5459 and I cannot seem to find anything anywhere about what it is
    Thank you for your help in advance
    Re: Fanuc error 5459
    The parameter No. 19665 to No. 19667, No. 19680 to No.
    19744 for configuring the machine are incorrect.
    - The axis specified with parameter No. 19681 or No. 19686 is
    not a rotary axis.
    - In parameter No. 1022, the basic three axes are not set.
    - A rotary axis end point found by the NC with tool center point
    control type 2, 3-dimensional cutter compensation type 2, or
    the tilted working plane command is not within the range set by
    parameter No. 19741 to No. 19744.
    - No rotary axis end point was found with tool center point
    control type 2 or 3-dimensional cutter compensation type 2.
    Check the machine configuration and specification.
    - On a machine whose rotary axis is a virtual axis, tool center
    point control type 2 or 3-dimensional cutter compensation type
    2 was specified.
    - When programming is performed in the workpiece coordinate
    system, tool center point control type 2 or 3-dimensional cutter
    compensation type 2 is specified.
  1. Fanuc error 998 ROM Parity Error ???
    By ED209 in forum Fanuc
    Last Post: 02-07-2022, 10:02 AM
  2. Fanuc error 998 ROM Parity Error
    By Samyelnaggar in forum Fanuc
    Last Post: 10-29-2020, 06:58 AM
  3. Replies: 1
    Last Post: 04-04-2019, 12:51 AM
  4. Replies: 0
    Last Post: 05-05-2013, 05:40 AM
