586,051 active members*
3,590 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang GT Pressure switch connection?
Results 1 to 6 of 6
    Jun 2009
    110
    Hello everyone,
    Need some guidance please. I'm setting up a new Quincy air compressor QT-7.5HP. Please review the attached pictures from manual. It's all wired up to a new Huanyang GT 7.5KW and runs fine from keyboard. I know other persons have wired control to the pressure switch but not quite sure which 2 terminals to connect. Can someone lend some advise here!
    Thanks in advance
    Steve in Maine and it's snowing!!
    15362
    Re: Huanyang GT Pressure switch connection?
    Quote Originally Posted by Barefootboy4 View Post
    Hello everyone,
    Thanks in advance
    It would be S1 and Com this can only be a switch with no voltage, so check the pressure switch that in the closed position there is no voltage across the 2 connections of the switch
    You will then have to change a Parameter for remote control
    P0.01=1 this may need to be 2
    P05.01=1
    Mactec54
    Jun 2009
    110
    P05.01=1
    Thanks for the help.
    It worked!
    15362
    It worked!
    Which Parameters did you use, just for my notes?
    Mactec54
    Jul 2013
    4
    It worked!
    Any chance you can forward your parameters? I am doing the same Pressure Switch wiring and those 2 parameters aren't enough to get anything to happen. Thank you!
    15362
    Quote Originally Posted by contilon View Post
    Are you using the same VFD Drive and what are your motor specs
    Mactec54
  1. Replies: 1
    Last Post: 10-12-2020, 09:23 AM
  2. Replies: 7
    Last Post: 05-28-2019, 03:46 AM
  3. Pressure switch
    By Mike T. in forum Haas Mills
    Last Post: 11-16-2009, 05:19 AM
  4. pressure switch
    By bibi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-07-2008, 08:01 PM
