586,051 active members*
3,712 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Deep VMC cuts. 15-5 H1025 ~40HRC
    Question Deep VMC cuts. 15-5 H1025 ~40HRC
    So I was wondering what those experienced roughing and finishing (with a nice finish) would use to cut a part out of a 3"x4"x6" block of 15-5 H1025.
    I have some experience with the stuff and think I would lean towards a 5 flute endmill or so (helical maybe) and do some chip thinning. It's about 40 rockwell.
    I have some tall vertical features to finish. Walls etc... that are 3.25 inches tall.. My main questions are would it be a good idea to try and finish that all at once with a long flute endmill.... OR.. maybe get a solid shank endmill with only 1.0"LOC and step it down.....
    Anyways... just curious what those with time in the realm of heat treated 15-5SS would use... as far as tooling and approach...
    Thank you for any input!
    P.S.. What about reaming a small hole.. (.1242"-1246") reamer brands? SnF?
    Lightbulb Re: Deep VMC cuts. 15-5 H1025 ~40HRC
    Well... I just wanted to update for those who may want to know about tooling and SnF in the future for this material with some real shop trials.
    I've been having great success with using more "budget" like 1/2" endmills for the shorter lengths(.625"-1.25"). Using GARR VRX Series endmills. 4 fluters at around 250-300SFM. 15% radial stepover at around .0028IPT Chipload (~26IPM Feed)
    For the long guy in the deep pockets, Im using a HELICAL#82902 Ø.500" 5FL (*Chipbreaker*) Bullmill R.030 .625LOC with 3.375" of reach. Utilizing about .500" axial depth cuts, 172 SFM (1320RPM), with 10% radial stepover (.050") and a feed of 13 IPM (.002" chipload)... Let me tell you... This 5-flute dream is whispering through that hardened 15-5.. Im blown away... then again... there's nothing like the right tool for the job... I just hate cutting tough steels like that with anything less than 5-flute... However the 4s did do ok in the shorter lengths... I would have much preferred 5 for all but you know.... cheap boss...
    P.S.
    Check out the look of the chips of `15-5 (40HRC) from that long (3.375" Reach) 5 flute Helical endmill. **Attached below
  1. Z axis cuts too deep
    By BenDayJoe in forum Fadal
    Last Post: 05-11-2021, 07:32 AM
  2. Does tool life vary with interrupted cuts to continuous cuts
    By acejunker in forum MetalWork Discussion
    Last Post: 08-08-2014, 02:34 AM
  3. *Scared* Deep Cuts
    By Cosha in forum CNC Tooling
    Last Post: 07-02-2011, 05:09 PM
  4. VM2 Cuts too deep
    By paul smargiassi in forum HURCO
    Last Post: 05-15-2011, 11:14 PM
  5. Machining 40HRC mould cavity
    By Astonlee in forum MetalWork Discussion
    Last Post: 03-11-2009, 09:22 PM
