586,075 active members*
3,761 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > 3d CNC Wood Milling Carving Machine
Results 1 to 1 of 1
    Sep 2021
    4
    3D CNC Router For Sale
    A 3D CNC router machine is an industry classification of CNC router machines. It is a new type of CNC equipment in recent years, and its working principle is very similar to that of CNC milling machines. It uses engraving programming software to convert the content that needs to be engraved into standard G codes that can be recognized by the engraving machine control software and makes the three axes of the control machine move automatically in a continuous jog mode, so as to achieve the effect of automatic engraving.
    Wood engraving machine router processing samples
    3D CNC machine tools can be used for three-dimensional 3D processing technology, furniture three-dimensional footposts, human bodies, Buddha statues, Guanyin, sculptures, handicrafts, staircase handrails, musical instruments, etc. The 3D CNC machine tool can perform 3D engraving and cutting of wood, stone, foam, and soft metals to realize three-dimensional 3D processing. The huge 3D processing range enables 3D CNC machine tools to meet the requirements of handicrafts, gifts, and furniture manufacturing.
    1325 4 Axis Wood CNC Router 3D Woodworking Machine with Rotary Axis
    This is a powerful and affordable 4 axis CNC router machine for wood,which has the Linear ATC system with linear type tool library. This machine adopts 9.0KW air-cooled spindle and the drive system adopts servo motor.So it can process the wood, MDF, chipboard, plywood, crylic, plastic, soft metal and many other different materials very easily.Meanwhile this 4 axis CNC router table for sale machine features the 4th axis rotary device,which can process cylinder materials, such as wood legs, chair legs.And The rotary diameter and length can be optional.So,this machine now is widely used in the sign industry, furniture industry, decoration industry etc.
    Multifunctional Atc Wood Cnc Router Machine
    4 axis CNC wood carving machine
    The CNC router with rotary device is the one type of 4 axis CNc router. Besides the side position of rotary device, you could also mount smaller size rotary device on the working table. Except for the cutting, drilling, pocketing, routing, and other func tions that a 3 axis router machine can achieve, it is also good at making cylindrical parts. For example, wood table and chair legs, wood handrails, wood or plaster building columns, 3D statues of wood, rubber, foam, etc.
    3d wood carving machine https://www.igoldencnc.com/3d-cnc-mi...e-machine.html
    4 Axis CNC Wood Milling Machine
    This advanced 4 axis CNC wood milling machine includes a 9kw(12 HP) high frequency automatic tool changer spindle with an 8 position tool holder rack and its 4 axis controller support the spindle can rotate 180 degree.So this 4 axis CNC carving machine at a certain Simplifies the CNC product process to a degree.At the same time, this 4 axis CNC carving machine has many advantages, such as the maintenance free and efficient CNC cutting system and high speed precision cut.It can process wood, foam, MDF, HPL, particleboard, plywood, acrylic, plastic, soft metal and many other different materials.The 4 axis CNC wood milling machine will give your shop more production and profits.Now this machine for sale at affordable price。
    Split Type Polyfoam 4 Axis CNC Router
    Attached Thumbnails Attached Thumbnails 100x70.jpg   100x61.jpg   ATC-CNC-Router-420x420.jpg
